Bookmarks added to panel, open lister mode problem
  • rms
    rms
    Posts: 606 from 2004/11/27
    I have a problem here, I added to a panel Bookmarks. The Bookmarks are partitions and I'd like them to open in "List" and "All files" mode on snapshoted place on Ambient but it opens everytime in "Icon" and "Icons" mode in the middle of the screen. Does anyone know if this is possible?
    Also, what would be the name of the icon? Is it def_bookmarks.info in Deficons?
    Thanks for help.
  • »31.12.09 - 09:00
    Jambalah
    Posts: 820 from 2008/3/30
    Hi RMS and Happy New Year!
    As I see there's no way to configure the Bookmarks in Ambient prefs. But you can solve (almost) in another way.
    Download this:
    QOpenWB
    It's a command created by Ilkka Lehtoranta that extend the normal Shell command "Open", allowing to add some
    parameters like 'SHOWALL' and 'LISTVIEW'. Using a little script file you can open what you want.
    For example: QOpenWB DH3:MyFolder/MyFiles SHOWALL LISTVIEW
    Save the file, make it a script file and save it where you like (you can create an oppotune directory for those files).
    Then set the bookmark due to execute this script and you will see the fullpath list will open after a click.
    I wasn't able to modify size and position... sorry!
    The icon used was present in MorphOS 1.4.5 (MOSSYS:Ambient/Images) and was named "def-view.png" and it had no arrow above. I didn't find it in MorphOS 2.4.. I don't know where it could be...
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »01.01.10 - 11:03
    dake
    Posts: 204 from 2007/9/14
    @rms
    Go to Ambient settings -> bookmarks
    Select the name you want to change
    at the location type something like this:
    MorphOS:?view=List&mode=ALL&top=150&left=150&width=400&height=300
    unfortunately it does not read the snapshoted position, but doing it this way you can type it manually at least:)
    [ Edited by dake on 2010/1/1 19:41 ]
  • »01.01.10 - 16:37
    Jambalah
    Thanks Dake!
    One never stop learning!
    Pegasos II 1 ghz
  • »01.01.10 - 17:06
  • rms
    rms
    @ Jambalah and dake
    Thanks very much for these infos, this is really great!!! :-) It's even better that the top, left, height and width are entered because as these are LAN partitions the windows open on very Pegasos the same way.
    Thanks again.
  • »02.01.10 - 07:53
  • rms
    rms
    Hi all, entering postion and size info e. g. like this:
    PM1-Clients:?view=List&mode=ALL&top=180&left=240&width=540&height=740
    works fine!
    Now I would also need to enter the sorting information, like sorting by Date or sorting by Name from A>Z or the other way round from Z>A.
    Does anyone know if this is also possible?
    Thnaks in advance for your help.
    Best regards
    Christoph
  • »06.08.15 - 03:48
