Digita Organiser 2
    pan1k
    Posts: 147 from 2009/1/20
    Hello All,
    I ran across my old Digita Office CD. It had Ograniser 2 on it, which installed fine. When launched, the date/time configuration appears and then I get a screen that says:
    The Organiser screen could not be opened in the selected screen mode.
    I try NewMode and tried to promote it with no luck. Here is my Snoopium log:
    [1] [Organiser] [ChangeDir] [MorphOS:Organiser] [] []
    [2] [Organiser] [MakeDir] [MOSSYS:Data/Multiview/] [] [Fail]
    [3] [Organiser] [Open] [MOSSYS:Data/Multiview/Links] [Write] [Fail]
    [4] [Organiser] [Open] [MorphOS:Organiser/Organiser.info] [Read] [OK]
    [5] [Organiser] [ChangeDir] [MorphOS:Organiser/Supplements] [] []
    [6] [Organiser] [Open] [Installing Supplements] [Read] [OK]
    [7] [Organiser] [Open] [The Digita Family] [Read] [OK]
    [8] [Organiser] [ChangeDir] [MorphOS:Organiser] [] []
    [9] [Organiser] [ToolType] [SETTINGS] [] [Fail]
    [10] [Organiser] [ToolType] [SETTINGS] [] [Fail]
    [11] [Organiser] [Open] [PROGDIR:Fonts/DigitaSans.font] [Read] [Fail]
    [12] [Organiser] [Open] [FONTS:DigitaSans.font] [Read] [OK]
    [13] [Organiser] [Open] [PROGDIR:Files/organiser.config] [Read] [OK]
    [14] [Organiser] [ToolType] [CX_PRIORITY] [] [OK]
    [15] [Organiser] [Open] [NIL:] [Read] [OK]
    [16] [Organiser] [Open] [NIL:] [Write] [OK]
    [17] [« Requester Slave »] [ChangeDir] [Ram Disk:ENV] [] []
    [18] [« Requester Slave »] [Open] [muidebug] [Read] [Fail]
    [19] [« Requester Slave »] [ChangeDir] [MorphOS:Organiser] [] []
    [20] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Read] [OK]
    [21] [« Requester Slave »] [LockScreen] [Workbench] [] [OK]
    [22] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Read] [OK]
    [23] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Write] [OK]
    [24] [Organiser] [ToolType] [CX_POPUP] [] [OK]
    [25] [Organiser] [ToolType] [PUBSCREEN] [] [Fail]
    [26] [Organiser] [ToolType] [PUBSCREEN] [] [Fail]
    [27] [Organiser] [LockScreen] [ORGANISER] [] [Fail]
    [28] [Organiser] [LockScreen] [Workbench] [] [OK]
    [29] [Organiser] [Open] [NIL:] [Read] [OK]
    [30] [Organiser] [Open] [NIL:] [Write] [OK]
    [31] [« Requester Slave »] [ChangeDir] [Ram Disk:ENV] [] []
    [32] [« Requester Slave »] [Open] [muidebug] [Read] [Fail]
    [33] [« Requester Slave »] [ChangeDir] [MorphOS:Organiser] [] []
    [34] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Read] [OK]
    [35] [« Requester Slave »] [LockScreen] [Workbench] [] [OK]
    [36] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Read] [OK]
    [37] [« Requester Slave »] [Open] [env:mui/INTREQ.2.prefs] [Write] [OK]
    [38] [input.device] [Open] [NIL:] [Read] [OK]
    [39] [input.device] [Open] [NIL:] [Write] [OK]
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »26.07.15 - 12:47
    pan1k
    Fixed it. Told it to use Pubscreen=Workbench. Is there a way to specify a different pubscreen?
  • »26.07.15 - 13:15
    NewSense
    Posts: 1615 from 2012/11/9
    I thought you might have had another MorphOS user offer some other solution, but I am in the same position as you with Organiser 2, as I have to use the 'Workbench' option of screens to get it to run, as it does not seem to want to open on another 24 bit or 32bit screen that is saved in the MUI screen list.
    Do you also get the colours slightly different than they used to be on a Classic Amiga - as the TABS used to be Bright RED and YELLOW, and GREEN, etc. but on the Ambient (Workbench) screen they are almost pastel shades of what they should be, but it is great that the program still runs on MorphOS.
  • »27.07.15 - 23:10
    Posts: 35 from 2015/6/12
    I now use PolyOrga it does most of what Digita Organiser does and is native to MorphOS
  • »28.07.15 - 13:41
