internet speedtest
    amiga4001
    Posts: 454 from 2006/11/16
    I upgraded my internet connection upto 100Mb/s download.
    I tested this with a 1.7GHz pentium Laptop with XP the speed is more then the promised 100Mb/s.
    So I tested on my peg2 but speed on there is only half the speed off the XP laptop.
    Both machines on the same cable so no wifi.
    Is this a stack thing or something else?
  • »12.07.15 - 17:18
    Brumiga
    Posts: 277 from 2004/4/3
    You can get increase by modifiying the file sys:prefs/env-archive/sys/net/netstatck.config. Edit this file and at the bottom add those two lines, if not present, tcp_recvspace and tcp_sendspace. That would be so :
    TCP_RECVSPACE=102400
    TCP_SENDSPACE=102400
    On my 2 computers, pegasos 2 and powermac mdd I have increased the values as indicated and on a 16 mbits connection by my provider, orange, and I reach it or overcome it to 17 mbits stable. You can try to increase these values more but when downloading big files, as chrysalis.iso for example, the rate must stay stable, near of the highest. If you obtain a high value only a few seconds and then that falls a lot then your values are too high.
    Good courage.
    Brumiga
  • »12.07.15 - 18:26
    Posts: 12572 from 2003/5/22
    > Is this a stack thing [...]?
    Yes, it is.
  • »12.07.15 - 19:59
    Yasu
    Posts: 1724 from 2012/3/22
    I tried this on my Mac Mini but I can't really tell if there is any difference. Is there a reason not to put those two lines in or can I leave it there anyway?
    My MorphOS blog
  • »16.07.15 - 11:09
    amiga4001
    Same result here no difference in speed.
    Not a big deal,hoping for improvement in future mos versions.
  • »18.07.15 - 03:41
