MagicBeacon (updating MorphOS)
    boot_wb
    Posts: 874 from 2007/4/9
    Magicbeacon installs files to the SYS:MorphOS drawer.
    MorphOS update method replaces the entire SYS:MorphOS drawer.
    Consequently, when updating MorphOS this directory must be manually restored, or Magicbeacon reinstalled.
    This trick resolves that annoyance (a legacy of Magicbeacon's intended inclusion as a system component).
    1) Create the following drawers:
    SYS:Applications/Magicbeacon and
    SYS:Applications/Magicbeacon/Data
    2) Move the drawer SYS:MorphOS/Data/Magicbeacon to SYS:Applications/Magicbeacon/Data
    3) Add the following assign to user-startup
    4) Change the default tool path in SYS:WBStartup/Macicbeacon.info
    Assign Mossys: Sys:Applications/Magicbeacon ADD
    All done.
    Magicbeacon will now survive updating MorphOS.
    [ Edited by boot_wb 11.07.2015 - 09:28 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »11.07.15 - 06:09
    Posts: 2220 from 2003/2/24
    I think my solution is cleaner and simplier, no need for assigns or anything and it survives from the updates: I've just installed MagicBeacon stuff which goes to MOSSYS: to SYS: instead.
    If you install manually from the MagicBeacon archive, just copy the contents of MagicBeacon.lha:MagicBeacon/SYS/MorphOS/ to SYS: and everything else where it's supposed to go, and that's it.
    If you have installed MagicBeacon with Grunch, then you probably need to move:
    MOSSYS:C/SendBeacon to SYS:C/
    MOSSYS:Data/MagicBeacon to SYS:Data/
    MOSSYS:Locale/Catalogs/deutsch/MagicBeacon.catalog to SYS:Locale/Catalogs/deutsch/
    MOSSYS:Locale/Help/deutsch/MagicBeacon.guide to SYS:Locale/Help/deutsch/
    MOSSYS:Locale/Help/english/MagicBeacon.guide to SYS:Locale/Help/english/
    Generally everything should work similarly when stored in MOSSYS: or SYS: directories. It's just that things in SYS: are preserved in upgrade and in MOSSYS: not.
  • »11.07.15 - 07:15
    boot_wb
    I'll give that a try (i'd rather avoid adding to the Mossys: assign also).
    ..also, I'd missed the locale files entirely... several upgrades ago!
    ..and forgot about sendbeacon, which i've always kept in SYS:c (mossys:c is sacred!).
    [ Edited by boot_wb 11.07.2015 - 09:34 ]
  • »11.07.15 - 07:32
    Tom01
    Posts: 187 from 2009/9/20
    I have MagicBeacon installed in WORK:Applications/Desktop and an Icon in WBStartup to start it.
    In the Icon-Tooltypes set CX_POPUP=FALSE (double click it)
    Catalog files can simply be copied over to SYS:Locale/Catalogs/.
    No Assigns necessary, no need to copy it to MOSSYS:
    Data is stored in MOSSYS:Data/MagicBeacon and has to be copied back from the renamed MorphOS directory after an update of MorphOS.
    Sendbeacon can be copied to C: , the ARexx-Scripts can be copied to S: ,if you need them.
    [ Edited by Tom01 11.07.2015 - 19:30 ]
  • »11.07.15 - 13:09
    Posts: 12572 from 2003/5/22
    ...or you do as suggested by boot_wb or jPV.
  • »11.07.15 - 18:33
