Can't Connect to Internet, but am on Network
    XDelusion
    Posts: 602 from 2010/10/27
    I just plugged my Efika into my network. I am able to ping the network, play Odamex Co-Op, etc. but I can not access the Internet.
    Am using a static IP.
  • »24.06.15 - 16:34
    Cego
    Posts: 738 from 2006/5/27
    did you enter a dns server?
  • »24.06.15 - 17:01
    Posts: 1098 from 2004/9/23
    Go to network settings, switch to host and dns settings, enable primary dns server and enter the ip of your router.
  • »24.06.15 - 17:03
    XDelusion
    EDIT: Typo, it works now, thanks!
    [ Edited by XDelusion 24.06.2015 - 14:35 ]
  • »24.06.15 - 17:17
    _bigdan_
    Posts: 70 from 2009/1/7
    XDelusions : fix your DNS and and heaven will help you ;-P
    Cego, Geit : thanks to help newbies ;)
  • »24.06.15 - 19:16
