Posts: 2217 from 2003/2/24
TTEngine and MUICon stuff are nowadays part of the MorphOS distribution. You should not install them afterwards from any other source, you only get older versions of them to the system. The latest separate PowerTerm.mcc is from 2007, while with MorphOS you get version from 2014! I'd suggest you to remove all that stuff you installed now, and hopefully you installed them all to SYS: and not to MOSSYS: and didn't replace any existing system component by that.
Nlist was the key in this case I think, and it would have been enough alone to fix the problem.
If Snoopium said in some lines that it didn't find powerterm.mcc, but did it say on some other line that it finally did find it? It's enough that system finds it in one place, even though it's trying to open it from several other locations and fails on them. In any case, powerterm.mcc should be by default at SYS:MorphOS/Classes/MUI/ and doesn't need any manual installation.
When installing or updating new classes or libraries etc, always check if you already have it in SYS:MorphOS/ directories! If you have it there, don't install any other version anywhere! And if you don't have it there, then you can install it to SYS: directories (not ever in SYS:MorphOS/ aka MOSSYS:).
