Moderator
Posts: 441 from 2003/2/25
Hi
An update on this matter also, that I would like to point out.
The text we have is in swedish. The specifications for the card says it is without bootchip (and it is), and therefore not possible to boot from.
However in the Pegasos I can se units I have connected to the card, right now I only have a scanner connected, but i can see this in the open firmware prompt.
Therefore I believe it should also be possible to boot the Pegasos from a disk connected to this card, as you probably also then can read the disk from open firmware.
Have to try out this little later.
Gunne
Best wishes, Gunne
