MOs 1.4.2 Iso
    weiseb
    Posts: 210 from 2003/3/29
    Should I download the Isofile or is it only 1.4.0
    and the new Bootimage?
  • »06.03.04 - 19:59
    4pLaY
    Posts: 80 from 2003/2/17
    If you already have MOS1.4.x you only need the boot.img
    http://www.resistance.no
  • »06.03.04 - 21:05
    TheMagicM
    Posts: 1220 from 2003/6/17
    if you go to "About" in Ambient, you're not going to see 1.4.2,
    correct? It will still read 1.4 ?
  • »07.03.04 - 04:46
    weiseb
    @4pLaY
    thanks
    @TheMagicM
    Same here.
    But the Kickstartversion
    (open shell and type "version")
    is now 50.60
  • »07.03.04 - 08:45
    4pLaY
    It will only say 1.4 in the About :).
  • »07.03.04 - 09:10
    TheMagicM
    4play:
    cool. Thanks!
  • »07.03.04 - 12:50
