How do I find the IP address?
    FerruleMedia
    Posts: 20 from 2012/6/15
    Hi there!
    I have my morphOS machine connected to the internet using DHCP, but is there any way to show what ip address the machine has got?
    On os4 i had a shownetstatus-command.. is there something similar on MorphOS?
    best regards
    Torgeir
  • »13.05.15 - 17:38
    Posts: 3326 from 2003/3/5
    You can use ifconfig from a shell.
  • »13.05.15 - 18:01
    Posts: 2217 from 2003/2/24
    There are many ways, for example:
    - "IfConfig" command from the shell
    - SYS:Tools/NetStat from the icon and then look the Interfaces tab
    - "SYS:Tools/NetStat -F" command from the shell
    - My scripts which parse the output from the previous commands to cleaner form: http://jpv.wmhost.com/jpv_software/ShowIPAddress-scripts.lha
  • »13.05.15 - 18:04
    igracki
    Posts: 469 from 2003/2/24
    OT, thanks jPV, through your script I learned that the ECHO command can output a substring! Very cool!
  • »15.05.15 - 15:48
