Wazp3D Apps
    Cego
    Posts: 738 from 2006/5/27
    I wanted to know what the current supported apps are.
    Al the games i tried didnt work.
    Wipeout works with the original starter only, but crashes at the second stage.
    When i use the WipeOut Loader i'll get a black screen graphics randomly flashing up for a millisecond.
    The same with Payback and Shogo.
    I tried all different settings in the wazp3D Prefs, but it didn't help. Is there something i'm doing wrong or is it because of lacking wazp3D/tinygl features/bugfixes?
  • »31.12.14 - 13:27
    Cego
    btw, when i exit Payback for example an iconx output appears saying "hackfullsize bm 0 640x960"
    Don't know what that means, but in the payback setup i chose a 640x480 screen mode.
  • »31.12.14 - 13:30
    Posts: 34 from 2013/6/20
    wipeOut demo: run on my powerbook G4
    MadWizards demo: run on my powerbook G4
    Shogo: fail on my powerbook G4
    I dont have other games or apps to test on my g4
    Heretic has been reported to work
    OS4 progs dont works due to OS4emu limitations
    OS3 progs seems to works
    It mean that the apps wanted to open a screen size that dont exist on this machine so the screen mode has been promoted to an other screen mode
  • »31.12.14 - 15:37
    Cego
    thats kinda odd. i did select a 640x480 screenmode in the game setup of payback. so why is it trying to open a 640x960 screenmode?
  • »31.12.14 - 15:40
    Cego
    hmm i tried the payback demo and there are the same symptoms ??? seems like somethings wrong with my config.
    [ Edited by Cego 31.12.2014 - 20:06 ]
  • »31.12.14 - 18:05
    Posts: 2073 from 2003/6/4
    W2097 works here (Powerebook 5.6). At least in windowed mode. But only on non resized window, if the window gets resized there's only gfx darbage. On double buffered screen it runs, too. But the gfx is flashing like mad which makes it unusable.
    Guess playing with the Wazp3D settings could imagine the situation.
  • »01.01.15 - 07:09
    Ok it seems to begin a few confusing as some people have the latest Wazp3D and others not
    So here it is my current build
    http://thellier.free.fr/Wazp3D.zip
    See ReadMe for changes since Aminet release
    Happy New Year to All
    Alain Thellier - Wazp3D
  • »02.01.15 - 10:44
    Cool_amigaN
    Posts: 776 from 2011/11/30
    @thellier
    Can you please check if Wazp3D is compatible with Mark's Wipeoutloader? Cause I am certain there must be some incompatibility, since if I load the game with bigfoot's loader I get the black/trashed graphics that my friend Cego explained up above.
    Using original executable I managed to get into the game and play one round however I get constant brief lagging(pausing) every 3-4 secs.
    Furthermore can you post your Wazp3D prefs that make Wipeout compatible with R300 cards on MorphOS as seen in your youtube video?
    FYI my MorphOS system is a PowerMac G4 featuring a flashed 9800Pro.
    EDIT: Btw Using the original loader results to an error regarding No suitable 16-bit TEXFMT available for selected screenmode (no matter what screenmode I select or even run the game in window mode). Also a cli output appears from Wazp3D as seen below:
    Loading Wazp3D.cfg
    Wazp3D.cfg loaded
    Wazp3D:Renderer=4
    hard/bitmap= 834398124
    HackFullSize bm 834398124 640X480
    ^^This continues for several hundred lines
    MPEG: Playing mpeg/w97intr.mpg
    Loading Wazp3D.cfg
    Wazp3D.cfg loaded
    Wazp3D:Renderer=4
    hard/bitmap= 795432844
    HackFullSize bm 795432844 1280X1024
    [ Edited by Cool_amigaN 08.04.2015 - 20:24 ]
  • »08.04.15 - 16:19
    Cego
    WipeOutLoader does work but only in window mode. But as soon as you resize the window the graphics will turn black again and you'll have to restart the game.
  • »08.04.15 - 16:47
