Synergy keymap not correct
    TheMagicM
    Posts: 1220 from 2003/6/17
    Very cool app...well once I get it working.
    I'm running 3.6 on my G5 with Synergy...my "server" is my laptop running Debian with Synergy 1.5.
    When I jump to the G5 and start typing, the key map is all wrong. None of the letters pressed are correct. Anyone have a fix?
  • »08.07.14 - 11:25
  • rms
    rms
    Posts: 606 from 2004/11/27
    I also wondered (though I didn't test yet) how the keyboards behave, because in the advanced settings there is a server keyboard mapping only for windows or mac os US!
    So how would this behave if I have a windos machine (acting as the server) with swiss french keyboard and also the morphos machine with the same mapping?
  • »09.07.14 - 02:47
    Posts: 3326 from 2003/3/5
    TheMagicM wrote:
    I'm running 3.6 on my G5 with Synergy...my "server" is my laptop running Debian with Synergy When I jump to the G5 and start typing, the key map is all wrong. None of the letters pressed are correct. Anyone have a fix?
    Sorry but Linux servers are not currently supported. As Chris already pointed out, you can either pick a Windows or OS X server. If you are willing to help, I can build a debug version of the client and let you test and fill out all the necessary structures yourself - I'd assume it'd be about 4 hours of work, given you have minimal understanding of C code structure and MorphOS keymaps.
    As for Swiss mapping - I have only tried German and Polish keyboards and they both worked, so I could guess the Swiss one will work as well.
    Sadly, Synergy as well as VNC have no proper way of translating keyboard input.
  • »09.07.14 - 04:44
    TheMagicM
    I dont know anything about MorphOS keymaps..but I'm willing to give this a shot in my spare time.
  • »09.07.14 - 10:53
    Rats
    Posts: 33 from 2013/1/22
    I was wondering is there anyway to open the client and connect automatically when Morphos starts.
    I tried the auto-connect thing and put it in startup folder. Everytime I restart the ip adresse has to be inputted.
    Btw loving this software so far :)
  • »10.07.14 - 10:12
    TheMagicM
    ...still waiting on giving it a shot myself to map Linux structures...
    Not a Windows or OSX user so that doesnt help me at all.
  • »07.08.14 - 11:58
    Quit the app once you've configured it and it'll store the settings. I will fix this for 3.8.
  • »08.08.14 - 05:02
    *Someone* offered a bounty for Linux support so I put that on hold for a while...
  • »08.08.14 - 05:02
    Develin
    Posts: 100 from 2003/4/19
    I think I know who suggested the bounty and I would gladly contribute to it :)
    Maybe we could use a common bounty portal?
  • »08.08.14 - 09:57
    TheMagicM
    Well..its a very handy utility..so if I need to I'll use my friend's Paypal account to contribute. Update this thread with a link if you decide to remove it off of hold.
  • »08.08.14 - 12:34
    Rats
    Worked out the auto-start connection to a server thing thanks to this conversation
    http://blog.remotecpu.com/?p=7
    you need to set
    STARTPRI=127
    TOOLPRI=127
    DONOTWAIT
    In tooltypes
  • »05.04.15 - 16:48
