How to print documents?
    Leon
    Posts: 93 from 2003/11/28
    Hi, I am trying to print some PDF via a HP Laserjet 1100, currently
    there are no built-in drivers in MorphOS, but I assume there is a
    compatible driver there. Anyway, when I try to print something I get a
    system request to insert PS: in any drive. I think this is PostScript,
    but what should I do?
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »04.03.04 - 06:46
    Spidey
    Posts: 568 from 2003/2/24
    Hi Leon,
    You'll have to wait for the next MOS-version if you want to print with MOS.
    There are some troubles with it at the moment.
    Bye,
    Spidey
  • »04.03.04 - 10:25
    matt3
    Posts: 784 from 2004/2/10
    I thought that TurboPrint was working fine in Morphos 1.4?
    What problems are there with Morphos and printing?
    Matt
  • »04.03.04 - 13:51
    Posts: 2090 from 2003/6/4
  • »04.03.04 - 14:04
    Posts: 159 from 2003/10/24
    There have been some people reporting that they have their printers working. I have yet to find anyone that has a working HP printer though. I hope that this is corrected by 1.5 since this keeps me from completely switching over at my house.
    --Mithalas
  • »04.03.04 - 14:27
    Leon
    Thank you very much, but what is this PS: assign? I assume this should be the folder where the PostScript fonts are, am I right? I am completely far from having experience about PostScript.
    Proud owner of:
    Efika
  • »04.03.04 - 15:29
    Tomo
    Posts: 94 from 2003/7/29
    At the moment I'm using Studio for Pagestream to print. It works fine, it only gives a warning: "Error 12 in IFF read module. Reason: IFF syntax error"
    After clicking on it the computer starts to print without any problems!
    Tom
  • »04.03.04 - 16:18
    Spidey
    Hello Tomo,
    Do You have a Peg 1 or a Peg 2?
    AFAIK printing with the Peg 2 doesn't work.
    I had the Peg 1, with that I could print from various programs.
    So, I'm very curious with which Peg you've printed so far :-)
    Bye,
    Spidey
  • »04.03.04 - 18:24
    Druideck
    Posts: 82 from 2003/5/6
    I got my old HP672c to print okay from Peg 1 with
    turboprint enabled. It seems to work with most
    software. It is a parallel connection.
  • »04.03.04 - 19:17
    Spidey
    Hello Druideck,
    I've got a HPDeskjet920C.
    Printing was fine on the Peg 1, except printing pictures. The colors were inverted or so.
    I did understand that GraphicPublisher V7.20 does work with Peg 1.
    Bye,
    Spidey
  • »04.03.04 - 20:04
  • jah
    jah
    Posts: 69 from 2003/3/24
    i had the same problem, i "solved" it by unchecking "Pure Black".
    my color cartridge will die sooner but i have right colors...
  • »04.03.04 - 21:14
    docgeddy
    Posts: 37 from 2003/7/31
    LaserJet are Postscript compatible, set the device in the print requester to "PAR:" in APDF and then the printer prints the whole thing.
    I've got a LaserJet 2200 and it works.
    But I heard the parallel.device for PegII is broken (i've got a Peg1), perhaps it doesn't work at all. Try it.
    DocGeddy
    Member of Butterfly Army
  • »05.03.04 - 03:33
