Samba problem
    Cego
    Posts: 738 from 2006/5/27
    Hi there!
    i've installed Samba according to this guide:
    http://sambaforamigaos.wordpress.com/
    I did all the changes to the config files correctly, but somehow only nmbd will be started after a minute when booted up. smbd won't start no matter how long i wait.
    I also checked protection bits of smbd. all paths are complete and ok. Anybody an idea or tips?
  • »08.10.14 - 16:35
    Cego
    the samba server is installed on my PowerMac G5. Still when i try to connect with my Powerbook G4 i get the following samba log on my G5
    [2014/10/08 19:41:53, 0] smbd/service.c:(252)
    powerbook (192.168.178.29) couldn't find service share
    [2014/10/08 19:44:08, 0] smbd/service.c:(252)
    [2014/10/08 19:45:09, 0] smbd/service.c:(252)
    powerbook (192.168.178.162) couldn't find service share
  • »08.10.14 - 16:47
  • Visitor
  • On Daisuki spoofing as IPad makes it appear the playing interface, but when playing site responds that it "could not resolve host name".
  • »14.03.15 - 08:50
    bash64
    Posts: 977 from 2010/10/28
    Samba (at least on linux) does not run as a service in the background.
    It is plugged into inetd and is run as needed (when someone tries to connect to the samba port number on your machine).
    I am not aware of how it is setup on MOS.
    I downloaded the MOS version of samba and ran the installer.
    http://aminet.net/comm/tcp/samba-3.0.4-morphos.tgz
    During the days of Amiga OS 3.1 you had to set it up the same way (to run as needed) using Miami.
    [ Edited by bash64 14.03.2015 - 09:57 ]
  • »14.03.15 - 12:56
    Tom01
    Posts: 187 from 2009/9/20
    Is Samba-3.0.4 working correctly?
  • »14.03.15 - 16:51
    bash64
    I installed it with smbfs and I can mount things.
    I don't know if smbfs comes with samba built in so I cannot say for sure Samba works.
    I'd have to set it up to share my amiga folders to my linux laptop to be for sure.
  • »14.03.15 - 20:04
    Posts: 12558 from 2003/5/22
    > I installed it with smbfs [...]. I don't know if smbfs comes with samba built in [...].
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11106&forum=18&start=7
  • »15.03.15 - 04:32
