Replacing the PC with Pegasos
    muckboy
    Posts: 47 from 2004/1/15
    I am hoping that when I get my Pegasos2, it will replace my PC entirely. MorphOS has already got most of the applications I need, except for a modern web-browser (this is important for me for eg. online bank-accountance). My idea is to install both MorphOS and Linux (the latter mainly for using Mozilla).
    Problem: I am a total newbie when it comes to linux. I have no experience in it whatsoever.
    Questions:
    1. Which linux-distro should I go for (I only need basic stuff..)
    2. Is there such thing as "a dummies guide for installing a linux-distribution on the peg2"?
    3. If not, any tips on how i should arrange the partitions?
    4. Is it difficult to make a dual os-boot selector on startup (morphos, linux..)?
    5. Are there linux-live-on-cd for Pegasos2 yet?
    Thx in advance!
    - Muck!
    PegasosII/G4@1GHz | 512MB PC2100 ECC/REG | Radeon9200/128MB | Seagate Barracuda 160GB@7200RPM
  • »02.03.04 - 19:39
    gunne
    Posts: 441 from 2003/2/25
    Hi
    Browsers for MorphOS:
    Ibrowse is the most compatible (bank-services etc) out from my opinion. Voyager load pictures faster as it is PPC.
    Linux:
    If you are somewhat familiar with Linux, go for Debian. Or if you want to compile gor for Gentoo.. :-)
    Partitions:
    Easiest to create everything from within MorphOS, and just mount and format in Linux.
    Its not difficult to make dualboot.
    Above is just my opinions :-)
    Greetings !
    Gunne
    Best wishes, Gunne
  • »02.03.04 - 19:51
    magnetic
    Posts: 2129 from 2003/3/1
    Muckboy
    Welcome to the club! Best thing for you to do is join
    linux.pegasosppc.com
    For a newbie use Debian
    if you go to that site you can download the boot.img called
    di-2004.02.26
    put this in your mos boot partition and you can boot it from the OF with this
    boot di-2004.02.26 devfs=mount video=radeon (if you have this card)
    this will then take you to a net installer - it will take a couple of hours with hispeed but its easy.. you can get help in the forums on that site.
    Voyager may access your bank but Ib2.3 is probably better for that. Although with Mozilla it should work np
    good luck
    magnetic
  • »03.03.04 - 00:51
    poundsmack
    Posts: 1346 from 2003/6/7
    for easy to use linux gor with mandrake or yellowdog......as far as i know yellowdog will be able to install on the peg very well on its next official release.
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »03.03.04 - 02:17
  • Targhan
    Posts: 2833 from 2003/2/7
    This brings up the inevitable question, how long before one can run IE from within win98 running on Bochs for Mos? :-)
    :idea:Targhan
  • »03.03.04 - 03:42
    magnetic
    Targhan
    Unless there is some miraculous recompile of Bochs it will never be fast enough. I can use IE 5.2 for Mac OS on my Peg with MOL anyway!
    magnetic
  • »03.03.04 - 03:46
    poundsmack
    bochs 2.1.1 is MUCH faster.......but i am guessing there is no morphos port yet....
  • »03.03.04 - 04:20
    muckboy
    Thanks for the help, guys.
    @Magnetic
    Should I install MorphOS first and set up the partitions from MOS, before i install Debian?
    Newbie question: What size should the linux swap-partition be set to?
  • »03.03.04 - 09:19
    Jupp3
    Posts: 1193 from 2003/2/24
    The bigger question (for me) is when I will be unable to do that... :-)
    I'm trying to remove Internet Explorer from my Win98 hardfile (as it mainly just slows booting and general use, eats memory and makes system generally "less stabile")
    Windows 98 lite installer seems to have some problems with Bochs, but if I will succeed some day, I'll sure tell you how :-)
  • »03.03.04 - 09:38
    Posts: 2074 from 2003/6/4
  • »03.03.04 - 10:53
    cecilia
    Posts: 459 from 2003/8/30
    ugh! I know I sing this song alot, but WHY would anyone want to use that crap IE when there are SO many better browsers?????
    Just Say NO!!!!!
    :(o):
  • »03.03.04 - 14:27
    cecilia
  • »03.03.04 - 14:33
    liquidbit
    Posts: 408 from 2003/10/12
    muckboy,
    Installing debian linux is a piece of cake.. with the help of the irc-morphos guys(including me) ofcourse.
    When you are done with the installation..(this a good link: Link), then do not forget to visit this site to learn everything about debian:
    www.aboutdebian.com
  • »03.03.04 - 18:09
    Bifford
    Posts: 283 from 2003/2/24
    Hi Magnetic
    just how many more websites like this fab one are you hiding up your sleeve without telling anyone about???
    Ive added http://linux.pegasosppc.com to the MWD now.
    Give me more to add m8! ;)
    TTFN
    Bifford
    Bifford the Youngest
  • »03.03.04 - 18:25
