Assign MUI: to MOSSYS: ?
    Estrayk
    Posts: 142 from 2003/12/30
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »03.03.04 - 12:32
    Wishmaster
    Posts: 342 from 2003/6/29
    MOSSYS: is totally wrong.
    Such an Assign is normally not needed.
    Better install such prg by hand.
    Put additional MUI classes to SYS:Classes/mui
    Pegasos PPC
  • »03.03.04 - 12:35
    Robin
    Posts: 741 from 2003/2/24
    Well, a little difficult but better dont
    assign it at all. Install the applications
    by hand.
  • »03.03.04 - 12:37
    Estrayk
    ok, thx to both.
  • »03.03.04 - 12:39
    hooligan
    Posts: 1948 from 2003/2/23
    My MUI: points to MorphOS:morphos/MUI/ .. haven't had problems.
  • »03.03.04 - 12:42
    cecilia
    Posts: 459 from 2003/8/30
    my understanding is that MOS mui files are all installed in the MOSSYS:classes/mui/ directory.
    and that any 68k mui files that are needed by "classic" amiga programs are placed in the sys:classes or sys:mui directory as needed by the specific program.
    as i'm still new to this thing, don't go only by what I say. :angel:
    but I was able to get ImageFX and ZoneXplorer to work properly by paying attention to these issues.
  • »03.03.04 - 13:44
  • Targhan
    Posts: 2833 from 2003/2/7
    On the occations that I needed it, I just made a new temporary directory in ram. i.e., ram:mui/, ram:mui/libs/, etc. Then I made an assign of mui: to ram:mui. The secret to this is to check those libs before putting them into SYS:Classes/MUI/, then to remove that assign.
    :idea:Targhan
  • »03.03.04 - 14:28
