Synergy
    bash64
    Posts: 974 from 2010/10/28
    Any way to make it automatically Iconify after connecting?
    I like the fact that it will connect on startup.
    But it needs to shrink when it does. Saves me a step if it does.
  • »06.02.15 - 23:16
    bash64
    p.s. Sometimes on boot I get a 'netstack.log' when synergy comes up.
    Anyway to quiet this?
  • »06.02.15 - 23:57
    Posts: 3296 from 2003/3/5
    Open MUI settings for Synergy and you'll find the option there. This is a typical option or all MUI apps (except Ambient).
  • »07.02.15 - 04:55
    bash64
    Synergy does not have a MUI option in the main menu.
    Can this be accessed another way?
    Nevermind, found it under the Iconify drop down in the window bar.
    [ Edited by bash64 07.02.2015 - 09:40 ]
  • »07.02.15 - 12:18
    bash64
    New question:
    I need to change the IP that synergy connects to.
    Before, it saved the IP automatically.
    Now that I run it on startup I can change the IP all I want and it keeps going back to the old one on bootup.
    I don't see a config file and the information box has nothing.
  • »09.02.15 - 01:40
    bash64 wrote:
    New question:
    Quit it after you've changed the IP. This is fixed for the next update.
  • »09.02.15 - 05:28
    bash64
    worked, thanks
  • »09.02.15 - 13:02
