SimpleMail & Gmail
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Has anyone sucessfully configured Simple Mail to work with a Gmail account under IMAP?
    If yes, what's the correct options on the Simple Mail account screen?
    I 've followed the Gmail configuration walkthrough but I cannot establish a connection with the server (and Simple Mail doesn't provide any other info).
  • »04.02.15 - 10:33
    Posts: 12552 from 2003/5/22
    > under IMAP?
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10060&forum=9&start=16
    Which version of SimpleMail are you using?
  • »04.02.15 - 12:35
    DanicaTalos
    Posts: 460 from 2010/10/15
    MOS Version 1.1 works great with GMail / IMAP! :D
    [ Editiert durch DanicaTalos 04.02.2015 - 15:58 ]
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.20
  • »04.02.15 - 13:49
    Cool_amigaN
    @Andreas
    Thanks for the hint, I 've updated to the latest version (1.1), still no luck though
    @DanicaTalos
    Can you please write down your account settings briefly?
    I 've enabled imap on the gmail preferences then went on SimpleMail->Settings->Configuration->Accounts->Add accounts
    Main preferences I have checked are:
    IMAP4, Server: imap.gmail.com, Port 993, Secure, Active and Avoid Duplicates are ON.
    On SMTP I have smtp.gmail.com, Secure, Port 465.
    However, I get a "Login failed, check Username and Password for this account" :(
    I've tried even with ASK option enabled to write down my username/password but for some reason it keeps failing..
    EDIT: Seems now it created a 2nd imap folder with the extension imap.gmail.com-0. Checked the username name under ASK option and it shows the following unreadable information: "+Yë"™»„ªOސÆÑ†q#žK‘Gp»À’`ìàÔçmÆÓígƒwRÕòåw§6²ãT¾Ù»
    ›ïaôƙ3™õ¯"
    Can SimpleMail accept also numbers as username? Mine is Stefkaro83 at GM etc.. perhaps that is causing some problem?
    [ Edited by Cool_amigaN 04.02.2015 - 20:13 ]
  • »04.02.15 - 16:08
    DanicaTalos
    Importent: In the Settings, you must write:
    NOT:
    Username: yourname
    Password: yourpassword
    correct:
    Username: yourname@gmail.com (yourname@googlemail.com)
    [ Editiert durch DanicaTalos 04.02.2015 - 19:45 ]
  • »04.02.15 - 17:44
    Cool_amigaN
    Ok, I managed to get it working :)
    Seemed that Gmail was blocking access to SimpleMail (got a notification mail from Google for illegal access to my account).
    For whoever faces the same problem in the future, after you have enabled imap on the gmail settings head on HERE and enable acceess fom less secure applications. OWB didn't do the trick and I had to resort on Mozilla/PC to enable that option. After you have successfully enabled it you will receive a confirmation mail from Google. Now go to SimpleMail account settings and fill in the blanks.
    Also, wasn't suppposed that SimpleMail 1.1 would display HTML and unicode (i.e. Greek letters)? Because both of them don't seem to work. HTML mails display just a url link (i.e. from Nike.com) and when I receive a mail to Greek I only get "____" (without the quotation marks).
  • »05.02.15 - 06:05
    nemesiswar
    Posts: 37 from 2012/11/12
    I wonder if theres gonna be an email client included in a future version of MorphOS.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »05.02.15 - 14:24
