Jalapeno - Can't Write Discs
    danwood
    Posts: 95 from 2009/10/5
    Hi ,I'm having a problem with Jalepeno on my G5 system running MOS 3.7.
    Every type of disc I try with any ISO, the software identifies the disc, then when clicking burn it just says Fixation then the disc ejects with an error that it cannot write the disc.
    Log below:
    Cdrecord-ProDVD-ProBD-Clone 3.00 (--) Copyright (C) 1995-2010 Jörg Schilling
    NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
    and thus may have bugs that are not present in the original version.
    Please send bug reports and support requests to <support@morphos-team.net>.
    The original author should not be bothered with problems of this version.
    MOSSYS:Data/Jalapeno/cdrecord: WARNING: Cannot set priority on this OS.
    MOSSYS:Data/Jalapeno/cdrecord: WARNING: This causes a high risk for buffer underruns.
    MOSSYS:Data/Jalapeno/cdrecord: Fifo not supported.
    scsidev: '2,0,0'
    scsibus: 2 target: 0 lun: 0
    Using libscg version 'schily-0.9'.
    MOSSYS:Data/Jalapeno/cdrecord: Warning: using inofficial libscg transport code version (T. Langer, J. Piszczek-scsi-amigaos.c-1.8 '@(#)scsi-amigaos.c 1.8 06/11/26 Copyright 1997,2000-2003 J. Schilling').
    Device type : Removable CD-ROM
    Version : 0
    Response Format: 2
    Capabilities :
    Vendor_info : 'PIONEER '
    Identifikation : 'DVD-RW DVR-107D'
    Revision : 'A707'
    Device seems to be: Generic mmc2 DVD-R/DVD-RW/DVD-RAM.
    Using generic SCSI-3/mmc-2 DVD-R/DVD-RW/DVD-RAM driver (mmc_dvd).
    Driver flags : NO-CD DVD MMC-3 SWABAUDIO BURNFREE
    Supported modes: PACKET SAO
    MOSSYS:Data/Jalapeno/cdrecord: Warning: Cannot read drive buffer.
    MOSSYS:Data/Jalapeno/cdrecord: Warning: The DMA speed test has been skipped.
    Mounted media class: DVD
    Mounted media type: DVD-R sequential recording
    Disk Is not erasable
    data type: standard
    disk status: empty
    session status: empty
    BG format status: none
    first track: 1
    number of sessions: 1
    first track in last sess: 1
    last track in last sess: 1
    Disk Is unrestricted
    Disk type: DVD, HD-DVD or BD
    Track Sess Type Start Addr End Addr Size
    1 1 Blank 0 2298495 2298496
    Next writable address: 0
    Remaining writable size: 2298496
    MOSSYS:Data/Jalapeno/cdrecord -dev 2,0,0 -v minbuf=25 gracetime=0 -eject driveropts=burnfree -sao -data Work:Downloads/en_windows_8_1_pro_vl_x64_dvd_2971948.iso
    TOC Type: 1 = CD-ROM
    scsidev: '2,0,0'
    Driveropts: 'burnfree'
    SCSI buffer size: 64512
    atapi: 0
    Version : 0
    Response Format: 2
    Capabilities :
    Revision : 'A707'
    Current: DVD-R sequential recording
    Profile: DVD+R
    Profile: DVD+RW
    Profile: DVD-RW sequential recording
    Profile: DVD-RW restricted overwrite
    Profile: DVD-R sequential recording (current)
    Profile: DVD-ROM
    Profile: CD-RW
    Profile: CD-R
    Profile: CD-ROM
    Drive buf size : 1605632 = 1568 KB
    FIFO size : 0 = 0 KB
    Track 01: data 3673 MB
    Total size: 3673 MB = 1880929 sectors
    Current Secsize: 2048
    Total power on hours: 154154
    Blocks total: 2298496 Blocks current: 2298496 Blocks remaining: 417567
    Starting to write CD/DVD/BD at speed 4 in real SAO mode for single session.
    Last chance to quit, starting real write 0 seconds. Operation starts.
    BURN-Free is ON.
    Starting new track at sector: 0
    Track 01: 0 of 3673 MB written.MOSSYS:Data/Jalapeno/cdrecord: Input/output error. write_g1: scsi sendcmd: no error
    CDB: 2A 00 00 00 00 00 00 00 1F 00
    status: 0x2 (CHECK CONDITION)
    Sense Bytes: 70 00 04 00 00 00 00 0E 00 00 00 00 1B 00 00 00 00 00
    Sense Key: 0x4 Hardware Error, Segment 0
    Sense Code: 0x1B Qual 0x00 (synchronous data transfer error) Fru 0x0
    Sense flags: Blk 0 (not valid)
    cmd finished after 0.003s timeout 200s
    write track data: error after 0 bytes
    MOSSYS:Data/Jalapeno/cdrecord: A write error occured.
    MOSSYS:Data/Jalapeno/cdrecord: Please properly read the error message above.
    Writing time: 5.104s
    Average write speed 550.7x.
    Fixating time: 0.014s
    MOSSYS:Data/Jalapeno/cdrecord failed returncode -2
    scsidev: '2,0,0'
    Version : 0
    Response Format: 2
    Capabilities :
    Revision : 'A707'
    data type: standard
    disk status: empty
    first track: 1
    scsidev: '2,0,0'
    atapi: 0
    Version : 0
    Response Format: 2
    Capabilities :
    Revision : 'A707'
    Profile: DVD+R
    Profile: DVD+RW
    Profile: DVD-ROM
    Profile: CD-RW
    Profile: CD-R
    Profile: CD-ROM
    Total power on hours: 154155
    BURN-Free is ON.
    Writing time: 5.108s
    Average write speed 550.3x.
    Fixating time: 0.005s
  • »26.01.15 - 15:18
    Posts: 1390 from 2010/1/6
    This problem is kown from the past and should be fixed in present MOS-versions.....and it depends on type of DVD-drive (FryingPAN also won't work)!
    Unfortunately there are still some drives (originaly used by Apple - eg. Pioneer) which shows that behaviour futhermore....
    I have the same problem on my G5 (Pioneer DVD-109 A912, NEC-HD-1300A).
    I've heared that some other drives will work (Sony, LG?) - maybe forum-members here can tell more about....
    [ Editiert durch Amigaharry2 26.01.2015 - 20:20 ]
  • »26.01.15 - 17:18
    Yasu
    Posts: 1724 from 2012/3/22
    Yes, my DVD-RW driver on my G5 doesn't work either.
    My MorphOS blog
  • »26.01.15 - 21:02
    deez
    Posts: 53 from 2003/5/28
    I have Plextor PX-760A and working fine on my G5 :)
  • »26.01.15 - 21:06
    bash64
    Posts: 977 from 2010/10/28
    Had no idea that Jalapeno uses CDRECORD by Jorg Schilling.
    Very nice.
    I always uninstall that damn forked shit Ubuntu installs and go back to cdrecord when using Linux.
  • »26.01.15 - 23:32
    What drive do you have?
  • »27.01.15 - 10:04
    Yasu
    @Amigaharry2
    A Sony DVD RW DW-Q28A. It reads well, and when I burn with Jalapeno it says it burning successfully (DVD-RW) but it just blanks the disk and nothing gets written.
    My MorphOS blog
  • »27.01.15 - 10:51
    Posts: 3336 from 2003/3/5
    I actually regret that now. We had to fix a ton of bugs in the cdrecord suite and Jörg Schilling really isn't someone you want to cooperate with.
  • »27.01.15 - 15:03
    Yasu
    @jacadcaps
    Are there any alternatives worth looking into?
    My MorphOS blog
  • »27.01.15 - 21:41
    bash64
    Yasu wrote:
    @jacadcaps
    Certainly not that terrible $@#$@#$ hack ubuntu implemented.
  • »27.01.15 - 22:29
  • szt
    szt
    Posts: 53 from 2004/10/9
    Is the FryingPan based on the cdrecord? Because the CD/DVD writing is not possbile with FryingPan on our G5 systems, either.
    MorphOS 3.9
    PowerMac 7,3, 1,8GHz,
    Radeon 9600
    300 GB SeagateHDD, 120 GB Samsung SSD
    LGM2382D, Canon MG7550
  • »28.01.15 - 16:27
    Don't think so.....the problem seems to be located deeper into MOS-hardwaredriver (IDE).......
    Question: DVD-Drives are normaly connected to IDE-Port (2nd.ide.device) of G5. Has someone tested that with a SATA - drive on SATA-port?
  • »28.01.15 - 17:03
    deez
    Yep, I tested Plextor PX-760SA and not working on SATA-port.
  • »29.01.15 - 14:58
    FYI:
    I had contact to F. Mariak in this case. He told me that this problem is caused by UDMA-support on G5. He also found out that this problem concerns only some drive-types. In next release of MOS there will be a work around to fix this problem.
  • »29.01.15 - 17:57
