Background on console
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello all, i have in my mui console a image as background, but when there is some long output on the screen, it displaces the image. Is there any way to get it fixed in position, so no longer moves the background?. Also, is possible to use a transparent background under the console?.
    Thanks in advance!!!
  • »10.01.15 - 18:10
    Posts: 3326 from 2003/3/5
    The background moves since otherwise all the contents of a console would have to be repainted - and that'd make scrolling craaaawwwlllll.
  • »10.01.15 - 18:32
