EAP authetication?
    Cego
    Posts: 738 from 2006/5/27
    Is this going to be supported in the future?
    http://en.wikipedia.org/wiki/Extensible_Authentication_Protocol
    I can't log into the WiFi net of the university with MorphOS as its using that authentication protocol.
    And what about VPN/Putty? Is there going to be any development in that direction? AFAIK Telnet and SSH is already supported by MorphOS (SDK)?
    [ Edited by Cego 05.01.2015 - 18:03 ]
  • »05.01.15 - 16:01
    Posts: 3337 from 2003/3/5
    It should already be supported - there's just no GUI for it. See http://manpages.ubuntu.com/manpages/precise/man5/wpa_supplicant.conf.5.html example 3 for instance. The easiest way would be to log in from Linux and simply copy the settings from the wpa_supplicant.conf file.
    Sounds like a lot of work...
  • »06.01.15 - 03:31
    Cego
    where do i have to copy the certificate file?
  • »07.01.15 - 13:50
    Where ever you'd like I guess - you have to specify the path after all.
  • »08.01.15 - 04:13
    Cego
    hmm, i've already tried that. I tried to configure it manually but it didnt work. Installing Linux is not really a solution, but maybe you could extend the wifi prefs to support the full features of the wifi options?
  • »08.01.15 - 08:27
    I have looked into this once, but there are far too many options to handle...
  • »08.01.15 - 08:40
