Window background transparency?
    Cego
    Posts: 738 from 2006/5/27
    Hey i was wondering if that is realizable? There is transperancy support in the new panel and in other apps in MorphOS, so i think that should not be a great deal or am i wrong?
  • »28.12.14 - 11:56
    Yasu
    Posts: 1724 from 2012/3/22
    Just the background and not the whole window? Why?
    My MorphOS blog
  • »28.12.14 - 12:13
    Cego
    just personal taste. this whole request has no purpose of any productivity. Making the whole window transparent doesnt look very nice in my opinion. I think making some parts of a window (like the window titlebar and the background) transparent is more aesthetic.
    The thing is that MorphOS still looks pretty much like a 90ish operating system and a bit eye candy wouldn't hurt.
  • »28.12.14 - 12:22
    Tom01
    Posts: 187 from 2009/9/20
    There is http://morphos-files.net/find.php?find=lucy
    But it slows down the GUI.
  • »28.12.14 - 13:49
    Cego
    @Tom01
    thanks, but thats not what i was asking for.
  • »28.12.14 - 13:50
    Posts: 3337 from 2003/3/5
    Well... the OS itself lets you make any pixel have different transparency level.
  • »28.12.14 - 16:25
    Cego
    What does this mean? adding a PNG picture with transparent alpha channel as backdrop should make it transparent? well i've already tried that. Didnt work that way.
  • »28.12.14 - 16:38
    Posts: 12572 from 2003/5/22
    I guess this means that MorphOS provides the function(s) necessary to write a program that does what you want to achieve, similar to how Lucy was written.
  • »28.12.14 - 20:38
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Well.. Its possible, but very hard to find the settings for.
    Ok.. A possible way is:
    1. Open the MUI - settings window of the program.
    2. Select left in the list "Window"
    3. Push the button "Background / Window"
    4. The settings Window "Adjust Frame & Background" of the program is now open.
    5. Change the background texture with a png with alpha chanal.
    6. Change the frame of the window
    7. find all other things... its very hard to find...
  • »28.12.14 - 21:29
    Cego
    when selecting a PNG picture with alpha channel, the alpha channel wont be transparent. it is just like a normal picture. No matter if i select a backdrop picture in MUI settings or Ambient settings.
  • »28.12.14 - 22:29
    It means the OS provides a way for applications to do this. Whether they use the feature or not is another matter...
  • »29.12.14 - 04:11
