Mounting .BIN files in Ambient?
    Cego
    Posts: 738 from 2006/5/27
    How can i mount a bin/cue file in MorphOS? I've got a game on iso with several audio tracks and would like to mount that. I know that i could convert it to .ISO but then i would lose all the audio tracks. So what i need is a tool to mount the bin file incl. the audio tracks!
  • »26.12.14 - 15:58
    analogkid
    Posts: 722 from 2004/11/3
    Why would you loose the audio tracks? They would be saved as seperate WAV files if you convert the BIN image with bchunk.
  • »26.12.14 - 16:12
    Cego
    thats the problem. the game wont read those files seperately. the audio tracks have to be mounted with the data track as one just like a real CD.
  • »26.12.14 - 16:26
    kolla
    Posts: 106 from 2003/4/22
    What you are looking for is in essence a virtual CD/DVD drive, that will deal with raw disc images as a real CD/DVD drive would, an emulator pretty much. I doubt this exists :)
    -- kolla
  • »28.12.14 - 02:16
    Cego
    no, just a virtual cd device that can handle bin/cue files with data and audio tracks.
  • »28.12.14 - 10:08
    Posts: 2217 from 2003/2/24
    The problem is, that audio tracks are separate from data track on real CD too. You can't just mount or see them inside data track. And if you can mount them by software somehow I bet your game won't understand them unless you have some kind of device level emulation there.
  • »28.12.14 - 14:28
