APDF dont open any pdf file now? earlier worked fine.
    Posts: 124 from 2014/9/22
    APDF dont open any pdf file now? earlier worked fine. Only thing what is changed i not have 1gigabytes of ram not 256megabytes. and MOS3.7 is now registered.
  • »11.12.14 - 14:35
    Old version works fine but one which comes MOS3.7 opens file requester but does nothing else. and one form MOS page
    dont do nothing... there is some very bad here.
  • »11.12.14 - 14:45
    Posts: 2201 from 2003/2/24
    I tried couple PDFs and they did open with APDF here. Any particular PDF file which doesn't work, but would be freely available to test?
    BTW. why don't you use VPDF? It's much better and newer PDF reader in MorphOS.
  • »11.12.14 - 15:09
    i dont know but i look it but these documents are part mos sdk and worked earlier fine. as i sayed now i try locate vpdf program. and actually cliking pdf seems use it. and its seems better.
  • »11.12.14 - 17:48
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    APDF can't correct work with TTF fonts embedet in PDF's.
    Newer Programs (Windows/Mac and the cairo.library in MorphOS 3.7) includet TTF-fonts in there docs.
  • »12.12.14 - 05:39
    Posts: 2073 from 2003/6/4
    Use VPDF instead of Apdf. It's located in morphos:applications.
  • »12.12.14 - 19:18
