OWB and YouTube login fails here in Norway
    MorphDelf
    Posts: 274 from 2004/2/20
    This happens when I try to login to YouTube. Gmail and Documents still works though.
    I have OWB 1.23 and tried to spoof as Firefox, Chrome, Safari and even OWB itself without any luck. I can watch YouTube clips, but not login anymore.
    Anyone else had this issue? I have deleted cookies, passwords, scripts etc. So I wonder where the problem is?
    Hope this can be solved as I love to work using MorphOS.
    Best Regards,
    Michal
  • »11.07.14 - 07:10
    Yasu
    Posts: 1724 from 2012/3/22
    I can confirm this. I have the same problem. Another things that has happened lately is that Youtube loads so slow that it's unusable if you want to watch online. And it eats up almost all the RAM in the process. It did not do this before. Even trying to switch between HTML5 and ordinary player loads for forever, and I have to stop because I got no more RAM left.
    Fab, what the f*ck did Youtube do this time?
    [ Edited by Yasu 11.07.2014 - 13:55 ]
    My MorphOS blog
  • »11.07.14 - 10:54
    Posts: 2220 from 2003/2/24
    Yep, can't login anymore. It would be better if people would start using Dailymotion or some other site which haven't got problems at all compared to youtube....
  • »11.07.14 - 13:37
    redrumloa
    Posts: 1424 from 2003/4/13
    Exact same thing here in the states. I was unable to login last night.
  • »11.07.14 - 13:47
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    From germany no problem .
    I log in to youtube over a google acount.
  • »11.07.14 - 16:27
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    Here in Italy I can see videos when spoofing OWB as IPad,
    But after loading the video and playing some minutes of it, then Youtube shows me pop up window saying "CONNECTION TIMED OUT - RETRY' YES, NO".
    This pop up is loaded again and again whatever is the answer. Very annoying.
    Also I got the same response as shown in the image posted by MorphDelpf when trying to connect to google or youtube or Gmail.
    Sites respond that cookies are not active, when they are correctly on.
    [ Edited by Raf_MegaByte 12.07.2014 - 21:16 ]
  • »12.07.14 - 16:16
    Doraemon
    Posts: 137 from 2003/7/1
    Hello.
    In spain the same problem :(
  • »12.07.14 - 17:51
    Condor
    Posts: 100 from 2005/9/1
    Same problem here. I can't login anymore.
  • »19.11.14 - 10:05
    Posts: 2094 from 2003/6/4
    I have the problem that I oftenly get redirected to the youtube start page. Also I still have redirection loop issues with quite some google services (merchant center, blogspot).
  • »19.11.14 - 11:02
  • rms
    rms
    Posts: 606 from 2004/11/27
    Best Regards,
    Michal
    I do have the same problem here in Switzerland, not possible to login with a combined Google/Youtube account :-(
    I wouldn't even care about logging in but here it seems that I'm not able to play videos in html5, so they played slow, even on an PM 2.7 Ghz and I think that is due to the fact that I'm not loged in. Correct?
    Does anybody have the same not being able to play in html5? Is there a solution?
  • »30.11.14 - 13:10
    Posts: 12558 from 2003/5/22
    > here it seems that I'm not able to play videos in html5, [...] and I think that is due to
    I don't even have any Google or Youtube account and can play HTML5 video on Youtube just fine (OWB 1.24 on MorphOS 3.7 on Mac mini G4).
  • »30.11.14 - 21:41
    Yasu
    Yes, you don't need to be logged in to view HTML5 videos. You can also try without HTML5 video setting on. It works for me too now with Fab's scripts.
    My MorphOS blog
  • »01.12.14 - 19:53
  • rms
    rms
    Yes it works without html5 but it's really much to slooooooooooooooow!
    I don't know what I do wrong here because it worked before, I mean html5 play, and it doesn't anymore.
    I need to see...
    I did have a look at the scripts stuff in OWB and even though I do have Yoututbe HTML5 Converter + Youtube FullscreenFix and Youtube - EZ Download enabled it seems not to play in html5 :-(
    Any idea what elese could be wrong?
    [ Edited by rms 02.12.2014 - 07:38 ]
  • »02.12.14 - 02:26
    No, it doesn't. Even with Youtube's HTML5 video setting off, Youtube sends its videos to OWB via HTML5, at least as long as you have the Flash plugin disabled. And with the Youtube scripts in use, the calculated video URL gets embedded into HTML5 on the fly. Put simply, OWB cannot play Youtube videos in any other way than via HTML5.
  • »02.12.14 - 05:32
  • rms
    rms
    I managed to have it work again! What I did is that I opened the Scripts Window in OWB and I deleted all the scripts, then I added all the scripts again and checked enable and now it works. Strange, don't know why this happened, but well...
    About the Flash plugin, it was anyway disabled!
    And I'm not sure that it is right that OWB can not play Youtube videos, because I could play them, the scrollbar was red, but I could not do a full screen and the video played very slow and scattered. So if OWB can't play them, and Flash plugin is disabled, what played them then?
  • »03.12.14 - 03:17
    > I managed to have it work again! [...] I opened the Scripts Window in OWB and
    > and now it works. [...] I could play them [...], but I could not do a full screen
    Sounds like this problem I had myself:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=9462&start=119
    > I'm not sure that it is right that OWB can not play Youtube videos [...].
    > [...] So if OWB can't play them
    Nobody said that OWB could not play Youtube videos.
    > [...] and Flash plugin is disabled, what played them then?
    OWB via HTML5, as I said.
  • »03.12.14 - 11:05
    Raf_MegaByte
    i want to inform forum that my problems with Youtube resolved automatically without i made anything to solve it...
    Now i can surf any video by spoofing OWB as IPad4.
    Must still chek if persist problems in logging in into Google+, Google Mail and Youtube account.
  • »03.12.14 - 11:43
    Rats
    Posts: 33 from 2013/1/22
    Also fails here in the UK
  • »04.12.14 - 08:47
