How do you use the new SMBFS in MorphOS 3.6 ?
    Posts: 3 from 2014/7/2
    I'm re-learning al things Amiga so excuse the newbie questions :-)
    How do I go about mounting an SMBFS share in the new MorphOS 3.6 ?
    Thanks!
  • »02.07.14 - 23:30
    analogkid
    Posts: 720 from 2004/11/3
    First question, do you have a SMB share setup on a NAS or Linux or BSD-like machine?
    AFAIR Windows 7 shares won't work. (only up to Windows XP)
    [ Edited by analogkid 03.07.2014 - 04:44 ]
  • »03.07.14 - 02:44
    Yup, got a Thecus NAS with a number of NFS, AFP anf CIFS shares.
    Storage side I've got down pat (since it's what I do for a job anyway :-) but just don't know the process on MorphOS to mount them up, before 3.6 I was using the 68K "smbfs" command, now I need to know what to use in 3.6
    Thanks!
  • »03.07.14 - 06:58
    Posts: 3326 from 2003/3/5
    Thanks!
    If you had it in Sys:C/ you are now most likely using the MorphOS smbfs since it's in MOSSYS:C
  • »03.07.14 - 07:55
    catohagen
    Posts: 297 from 2003/5/20
    Windows 7 share work fine, you just need to lower the security
  • »03.07.14 - 14:20
    Thanks!
    Ah ... OK I upgraded my 3.5 to 3.6 so I'll remove the 68K SMBFS from sys:c/ and see how it goes.
    Assuming it uses the same syntax ?
    Thanks
    Mark
  • »04.07.14 - 22:18
    Posts: 2217 from 2003/2/24
    Yes.
  • »05.07.14 - 04:05
  • rms
    rms
    Posts: 606 from 2004/11/27
    I'm just not able to connect on one of the win7 machines, another one works, slowly but works.
    So I wonder how do I lower the securtiy on win7? Can you please help/tell me?
    Thanks
    Christoph
  • »21.11.14 - 03:52
