Bounty for ANR?
    Cego
    Posts: 738 from 2006/5/27
    Hi there!
    Would you be interested in a bounty for a new and updated/fixed ANR version when the coders were willing to work on it again?
    I think MorphOS lacks a complete music player, i know there is mplayer but that still lacks a lot of features like playlist control and options (interprets, album, rating, most listened...), visualization, shoutcast search, equalizer, cdda support with automatic title name downloads, and so on...
    What do you think?
  • »04.10.14 - 08:40
    Posts: 1095 from 2004/9/23
    Cego wrote:
    Hi there!
    What do you think?
    There is Jukebox in MorphOS, which deals with a lot of stuff already.
    ANR was written in E and is non native, as the PPC compile never properly worked.
    Geit
  • »04.10.14 - 08:44
    diezi7
    Posts: 167 from 2005/7/25
    Other than Future Composer, and IFF files,
    which hang the player on my setup,
    It plays lots of files and it's a very
    complete player with support for many formats.
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »04.10.14 - 09:30
    Posts: 1521 from 2003/2/24
    If jukebox supported plugins I could port my existing players...
    I have also created and plugin support to cud player but yeah.... :D
  • »04.10.14 - 13:24
    amiga4001
    Posts: 454 from 2006/11/16
    Yes I would be interested.
    And I would donate.
  • »04.10.14 - 15:19
    Jupp3
    Posts: 1193 from 2003/2/24
    I thought it already used Reggae?
    Sure, f.ex. the lack of concept of subsongs might be an issue, but some existing plugins (f.ex. amos sound bank one) already got around it somehow...
    Also, this would workaround the common "GPL issue", which basically means that any software using GPL library must also be GPL (which has blocked f.ex. sid & uade plugins for ANR, since it isn't GPL)
    Since Reggae is an OS component, GPL doesn't stretch to that (and afaik, not to any programs using it either)
  • »06.10.14 - 12:30
    Posts: 12553 from 2003/5/22
    > GPL [...] has blocked f.ex. [...] uade plugins for ANR, since it isn't GPL
    Has it?
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=32&topic_id=6961&start=39
  • »06.10.14 - 17:18
    Jupp3
    Has it?
    Yes. As always (afaik)
    If not, it's either:
    1)Authors of the GPL software in question specifically allow it, which in practice makes that not GPL (in the normal "full" sense)
    or
    2)The people who created the plugin don't care about GPL, and license the infringing plugin anyway, even if it cannot be "legally" used with the program it was created for.
    -EDIT-
    To answer with a question: Is there a public ANR UADE2 plugin?
    [ Edited by Jupp3 06.10.2014 - 20:24 ]
  • »06.10.14 - 17:45
    BSzili
    Posts: 570 from 2012/6/8
    There neither a public or non-public ANR UADE2 plugin. I was working on one, but I lost interest, because ANR hangs my machine at exit. This is one reason why it could benefit from being open sourced or updated.
    [ Edited by BSzili 07.10.2014 - 09:22 ]
  • »07.10.14 - 08:20
    Yasu
    Posts: 1724 from 2012/3/22
    But Aminet Radio isn't worked on anymore right? I think it makes a lot more sense to work on Jukebox instead. Except maybe it's non-Winamp looks (if that's what people wants) it's a lot better MP3 player anyway IMO.
    An UADE plugin for it would be really appriciated.
    My MorphOS blog
  • »07.10.14 - 09:42
    So GPL wouldn't have blocked a release?
  • »07.10.14 - 12:31
    Correct, hence the bounty proposal by the thread opener.
  • »07.10.14 - 12:35
    BSzili
    As others have said Jukebox uses Reggae, which proved even more difficult to make an UADE plugin for than ANR. The problem is that UADE is a stripped off Amiga emulator. It emulates a minimal hardware and software environment for EaglePlayer replayers. It's not a simple library where you just hand over a chunk of data, and get back the rendered sound. The player has to communicate with the emulator in an event loop, process messages, reply to them, etc.
  • »07.10.14 - 12:42
    Jupp3
    @Andreas_Wolf
    Why ask BSzili? It's GNU people who wrote the license and a rather nice FAQ for it, which has this to say about creating GPL-based plugins for non-GPL-compatible programs:
    Can I apply the GPL when writing a plug-in for a non-free program?
    If the program uses fork and exec to invoke plug-ins, then the plug-ins are separate programs, so the license for the main program makes no requirements for them. So you can use the GPL for a plug-in, and there are no special requirements.
    If the program dynamically links plug-ins, and they make function calls to each other and share data structures, we believe they form a single program, which must be treated as an extension of both the main program and the plug-ins. This means that combination of the GPL-covered plug-in with the non-free main program would violate the GPL. However, you can resolve that legal problem by adding an exception to your plug-in's license, giving permission to link it with the non-free main program.
    I'd assume ANR plugins wouldn't count as "separate programs" in the defined way.
    And as we're on the subject, I assume this would cover Reggae decoders:
    Can I link a GPL program with a proprietary system library?
    Both versions of the GPL have an exception to their copyleft, commonly called the system library exception. If the GPL-incompatible libraries you want to use meet the criteria for a system library, then you don't have to do anything special to use them; the requirement to distribute source code for the whole program does not include those libraries, even if you distribute a linked executable containing them.
    (Damn, I almost feel like a lawyer now...)
    And I never said GPL would "block" it, Such usecase basically needs to either:
    1)License to be not-really-GPL instead or
    2)Developer to ingore GPL
    As explained before.
    First is definitely a special case. Second one, right or wrong? You decide.
    Of course should have added to list:
    3)Plugin as a separate program (as defined by GPL license)
  • »08.10.14 - 13:38
    BSzili
    The player itself (uadecore) is actually a separate program, and the plugin communicates with it via pipes. Of course IANAL.
  • »08.10.14 - 16:48
    > Why ask BSzili?
    Because he is the one who'd have decided whether or not he'd have released it. I guess if he deemed a release illegal, he wouldn't have started work on it. Starting to work on software usually implies the intention to release it once finished. And I think he'd have mentioned if he had negotiated a separate license with the UADE author.
    > Developer to ingore GPL [...], right or wrong? You decide.
    Of course, I disapprove of any license infringements.
  • »08.10.14 - 17:35
