Authoring DVD
    xyphoid
    Posts: 870 from 2008/7/11
    Is there a limitation on mastering a DVD? I had an Original file 716.7mb mp4, video length 2hrs 30min.
    I did (ffmpeg) -i file:mymorphos:file.avi -f dvd -target ntsc-dvd -r 29.97 -s 720x480 -aspect 16:9 -b 8000kb drive:temp/dir/file.mpg
    Then auth.xml. the burned output was 2:04 so I missed 26mins. I went back to check the converted mpg file and it was 3.9 gigs, but video length was also 2:04.
    The burn proces went ok, (not on morph this time though) and the video quality was nice, but I lost 26mins in the process somehow. What did I miss?
  • »06.10.14 - 23:41
    weiseb
    Posts: 215 from 2003/3/29
    Just an idea:
    Might be a filesize barrier problem.
    But as an amigaoid System shouldn't that be 2GB?
    Is sequential writing larger files (without 64bit DOS calls)
    possible?
    [ Edited by weiseb 07.10.2014 - 03:37 ]
  • »07.10.14 - 03:37
    Posts: 2220 from 2003/2/24
    Yea, what's the filesystem where that temp file goes? For example FAT32 has 4GB filesize limit.
  • »07.10.14 - 04:32
    Posts: 12572 from 2003/5/22
    For SFS:
    "Fixed writing to files larger than 2GiB"
    http://www.morphos-team.net/releasenotes/3.6
  • »07.10.14 - 04:33
    connor
    Posts: 650 from 2007/7/29
    mhhh so how large can files be on MOS >=3.6 when using SFS?
  • »07.10.14 - 15:20
    Posts: 1390 from 2010/1/6
    Better use ICE-FS........
  • »07.10.14 - 15:29
    >> For SFS:
    4 GiB (probably minus one or two bytes), I'd say.
  • »07.10.14 - 16:59
    Tcheko
    Posts: 544 from 2003/2/25
    Current SFS : 4GB-1 bytes.
  • »07.10.14 - 16:59
    xyphoid
    It is a FAT32 formatted drive, but mounted usb. I guess that would be it then. $#!^
    Oh well thanks! No fix for that then huh?
  • »08.10.14 - 00:52
    Only "fix" is to change the filesystem and re-format it, and of course losing the data in it. NTFS, EXT3, IceFS or similar depending on which systems you are going to use it. Although FAT is the most compatible, but has tighter limits.
    Or if your programs allow to split the temp file to smaller parts... I'd check the options too, it might be the easiest solution.
  • »08.10.14 - 03:10
