Bftpd 1.9
    caver99
    Posts: 131 from 2012/6/14
    i can find references for this FTP server for MOS but cant find anywhere that has a download, does anyone have if or know of a MOS native ftp server?
    Powermac quicksilver Dual 1ghz Dual Boot Morph OS 3.7 and OS X 10.5.8
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »23.09.14 - 15:37
    Tcheko
    Posts: 543 from 2003/2/25
    Afaik, there is no MorphOS native FTP server.
  • »23.09.14 - 16:23
    Posts: 12530 from 2003/5/22
    http://www.amiga-news.de/en/news/AN-2007-06-00016-EN.html
    http://morphos.lukysoft.cz/vypis.php?hledat=ftpd (the first two)
  • »23.09.14 - 18:05
    caver99
    Thanks but the link does not have a download i tied there as thats where i found out about the morphos version.
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »23.09.14 - 19:13
    I know. As you can see, I put my links as reply to Tcheko's posting, not to yours.
    The MorphOS porter of these two FTP servers is DJBase, but he hasn't logged into MorphZone since 2010. He provides a list of some of his MorphOS ports on his website there for download:
    http://www.amigaworld.de/software/morphos-portierungen/
    Unfortunately, neither of the two FTP servers is there. You may try to contact him and ask for them to be put on his site or send to you by email etc.:
    http://www.amigaworld.de/kontakt/
  • »24.09.14 - 06:18
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    If you can wait till weekend, i will try to compile this ftp-server.
    I download the source tonight from the net.
  • »24.09.14 - 14:16
    Jambalah
    Posts: 820 from 2008/3/30
    Carsten you are a unstoppable! :-)
    Great work!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.09.14 - 15:35
    Tom01
    Posts: 187 from 2009/9/20
    As there is no native ftp-server available at the moment, I recommend rc-ftpd 68k from Aminet.
  • »24.09.14 - 18:31
    Posts: 916 from 2004/1/24
    ...or you might want to try this MorphOS native successor of OrangeFTPd...OrangeFTPd 1.2:
    http://s000.tinyupload.com/index.php?file_id=96522815015936545233
    * It's a beta "works for me (tm)" release
    * Probably no support ;)
    * Read the guide on how to use it/set it up
    Enjoy.
    (crappy filehost, I know. Feel free to upload it to better/your own host)
  • »24.09.14 - 19:06
    caver99
    Enjoy.
    oooo thanks will give it a try thanks
    EDIT....
    I have downloaded and put it on my MOS machine but when i double click the icon nothing happens.
    [ Edited by caver99 25.09.2014 - 09:49 ]
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »25.09.14 - 06:09
    analogkid
    Posts: 715 from 2004/11/3
    Similar to Tom01, i recommend rc-ftpd from Aminet, too. It's easy to configure (by a MUI interface), and it's quite fast.
  • »25.09.14 - 07:47
    caver99
    OK thanks that would be great
    PS3 x5
    Xbox 360 x 6
    Wii x 3
    PSP x 3
    DS x 3
    Custom Gaming Rig
     :-o
  • »25.09.14 - 09:52
    You might want to check the protection bits of the executable. Open a shell, go to the OrangeFTPd directory and type "protect OrangeFTPd +rwed". It should run. If not use Snoopium to see if that shows anything.
    Enjoy.
    EDIT....
    [ Edited by Stevo 25.09.2014 - 12:10 ]
  • »25.09.14 - 10:25
    pegasos-sigi2
    Taaaaaaaaaaa Daaaaaaaaaaaaaaaaaaaaaaa stupid-ftpd-1.5
    Not bftpd but a ftp-server, too.
    Running:
    Type:
    stupid-ftpd [-f conf-file] [-p pid-file]
    Without the -f option stupid-ftpd expects the configuration
    in /etc/stupid-ftpd/stupid-ftpd.conf (Linux/Unix).
    With the -p option you can specify the pid-file, which you
    would like to use. On default no pid-file will be used.
    Quite the server: Control + C
    Change the .config-file!
    Try it out !
    Its a BETA !
    [ Edited by pegasos-sigi2 27.09.2014 - 18:55 ]
  • »27.09.14 - 17:54
    pegasos-sigi2
    Argl... Bug-Festival...
    I have a new version with debug... A bug is solved....
    This version sends now the rootdir contents. Transfer can now show into your dir ;)
    But now quit the server after getting the "LIST"-Command... argl...
    One more bug...
    [ Edited by pegasos-sigi2 27.09.2014 - 22:34 ]
  • »27.09.14 - 21:33
    pegasos-sigi2
    Argl... Exit() 's All the time argle...
    I coud upload on this server. hurray... but after upload ser server quit... one more Exit(0) ... argl...
  • »27.09.14 - 22:03
    pegasos-sigi2
    Most of Exit() are change to return(0). void to int.
    Now the server works nearly perfect. Upload, download, make dir, list dir works. Only the DEL Command didn't work .
  • »27.09.14 - 22:31
    pegasos-sigi2
    It Works now full! stupid-ftpd-1.5a
    Now we have a fast and ease to config ftp-server!
    In the archive exisit a debug-version, too.
    If you have problems, please use these version to find out,what going on.
    If i have more free time, than i can prog a MUI-GUI for these ftp-server.
  • »27.09.14 - 23:00
