Posts: 820 from 2008/3/30
Yes there is. It's Basilisk II and you can find here:
http://morphos-files.net/find.php?find=basiliskI can't tell if this is the best Apple II emulator for MorphOS since I've never used but it seems to be well done and with very good features. Pros: it is native, uses MUI and AHI. Cons: use full speed. Anyway I guess it's worth trying it
Edit:
I'm using a little and it's not that bad! I found others Apple ][ emulators on Aminet but not really exciting discovers...
Pegasos II 1 ghz
Powermac G5 dual 2.0 ghz
Powerbook G4 1.67 ghz 17
