Jalapeno
    Yasu
    Posts: 1724 from 2012/3/22
    Try to burn with Frying Pan. I'm also having problems with burning CDs with Jalapeno but Frying Pan can burn normally (although it can't handle .ISO files).
    It's a good way of finding out if it's related to the driver or Jalapeno.
    My MorphOS blog
  • »24.08.14 - 18:54
  • szt
    szt
    Posts: 53 from 2004/10/9
    I tried with Frying Pan, but the symptoms were the same(?) as VooDoo's.
    MorphOS 3.9
    PowerMac 7,3, 1,8GHz,
    Radeon 9600
    300 GB SeagateHDD, 120 GB Samsung SSD
    LGM2382D, Canon MG7550
  • »24.08.14 - 20:14
    Yasu
    @szt
    Ok, then we don't have the same kind of problem.
    My MorphOS blog
  • »24.08.14 - 20:36
    Posts: 3296 from 2003/3/5
    szt wrote:
    @ VooDoo, jacadcaps
    Could you possible tell me what the solution was for the problem when USB CD/DVD writer was detected as a Removable Disk?
    First of all, what exactly IS your problem?
  • »25.08.14 - 10:48
  • szt
    szt
    jacadcaps wrote:
    szt wrote:
    @ VooDoo, jacadcaps
    Absolutely the same as VooDoo's:
    When I want to use the USB CD writer, from the Jalapeno it is not possible to select the usbscsi device.
    [ Edited by szt 25.08.2014 - 12:28 ]
    MorphOS 3.9
    Radeon 9600
  • »25.08.14 - 11:27
    OK... I have an idea what is wrong in your case. Will have a look in a few days.
  • »26.08.14 - 05:32
  • szt
    szt
    That was my secret dream ;)
    MorphOS 3.9
    Radeon 9600
  • »26.08.14 - 06:44
