ushare possible on mos ?
    Mabo
    Posts: 67 from 2010/5/3
    Hi there!
    Can you help me understanding how to compile and use this app, please ?
    http://aminet.net/search.php?query=ushare
    Thank you :)
  • »23.08.13 - 17:55
    Posts: 1521 from 2003/2/24
    Mabo wrote:
    Hi there!
    Thank you :)
    Try this:
    cd src
    configure
    make
  • »23.08.13 - 23:16
    Mabo
    itix,
    Try this:
    cd src
    configure
    make
    Nuovo processo Shell 4
    Work:ushare/src> configure
    bin:sh: Comando sconosciuto
    Work:ushare/src> ushare
    ushare: Comando sconosciuto
    Work:ushare/src> make
    make: Comando sconosciuto
    Work:ushare/src> Makefile
    Makefile: il file non eseguibile
    Work:ushare/src>
    [ Edited by Mabo 24.08.2013 - 19:21 ]
  • »24.08.13 - 15:20
    Posts: 3296 from 2003/3/5
    Mabo wrote:
    How about switching to English so that we can actually understand the output?
  • »24.08.13 - 16:49
    Intuition
    Posts: 1116 from 2013/5/24
    You need to install the SDK.
  • »24.08.13 - 18:55
    Mabo
    Checking for compiler available...
    configure[501]: test: yes: unexpected operator/operand
    Checking for locales ...
    Checking for ifaddrs ...
    Checking for langinfo ...
    Checking for iconv ...
    Checking for libixml ...
    Error, can't find libixml !
    See file "config.log" produced by configure for more details.
    Work:ushare/src>
  • »24.08.13 - 21:19
    Work:ushare/src>
    As far as I can tell, this is part of the http://ftp.de.debian.org/debian/pool/main/libu/libupnp/libupnp_1.6.6.orig.tar.gz archive... Which again you'll have to configure/make or port.
  • »25.08.13 - 14:11
    Mabo
    jacadcaps,
    How to do this?
    I wait that someone do the job 'cause I understand nothing :(
    Thanks for reply Jaca ;)
    If I want that somone bring it to MorphOS what I ahve to do?
    [ Edited by Mabo 26.08.2013 - 14:43 ]
  • »25.08.13 - 16:30
    BSzili
    Posts: 570 from 2012/6/8
    Have you tried running the 68k version on MOS?
  • »25.08.13 - 17:37
    Mabo
    Yes, read 3 or 4 posts up
  • »26.08.13 - 14:21
    BSzili
    There's nothing in those posts which suggest that you actually tried to run it. You only tried to compile the sources.
  • »26.08.13 - 15:39
    clr666
    Posts: 86 from 2008/7/8
    Nice to hear about working mediaserver on Amiga. I have mediaserver on ubuntu, and mediaserver clients as iphone(airplayer) and PS3. Its useful for home network, where all media files stored in one place, and clients get it via streaming. Some modern TV's has mediaserver client built-in.
    Some times ago we discuss about mediaserver on morphos, but afair some devs sayd about non-available for now in netstack multicasts (?), without which upnp-dlna protocols not works.
    But, if ushare works on classic amiga, things looks not so sad.
    _______________
    wintel free
  • »27.08.13 - 14:35
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    68K version always freezes on startup on MOS (3.6). Anyone successfull in running it ?
    My new AV Receiver supports DLNA und having access to my media files on my Computer would be great...
  • »27.07.14 - 18:45
