Removing running tasks
    TheMagicM
    Posts: 1220 from 2003/6/17
    Lets say a task like e-uae is fubar.. I'm trying to use Scout to "remove", "freeze" "break"..and nothing seems to work. Other tasks sometimes get hosed, so how can I remove them without rebooting?
  • »29.06.14 - 01:31
    Posts: 3253 from 2003/3/5
    If there are windows, run ikill from shell and select the window. Be aware that this will only stop the task and close its windows - it won't free most of other resources.
  • »29.06.14 - 04:42
    boot_wb
    Posts: 874 from 2007/4/9
    Would it be sensible to integrate iKill into task manager's contex menu?
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »29.06.14 - 09:22
    I guess so :)
  • »29.06.14 - 13:11
