G4 not fast enough?
    Cool_amigaN
    Posts: 777 from 2011/11/30
    This one is of those E-UAE questions again: isn't a G4 1.6Ghz fast enough to play (all/most?) whdload games at full speed? Or is it E-UAE is crippled to the point that SWOS 95/96 won't run at full speed? Because sadly I noticed heavy fps drops while ingame and generally speaking, the gameplay was (in comparison) much - much worse than my 15 years old experience with a primitive WinUAE version and an Athlon 1Ghz with 512MB Ram.
    Perhaps there is a way to boost settings through the configuration?
    Here below is my own, what do you think about it?
    floppy_speed=400
    scsi=true
    scsi_device=ATAPI
    gfx_framerate=1
    gfx_width=1280
    gfx_height=1024
    gfx_width_windowed=640
    gfx_height_windowed=512
    gfx_fullscreen_amiga=yes
    gfx_fullscreen_picasso=yes
    gfx_linemode=double
    gfx_correct_aspect=true
    gfx_center_horizontal=smart
    gfx_center_vertical=smart
    show_leds=false
    sound_output=normal
    sound_bits=16
    sound_frequency=22050
    sound_channels=stereo
    sound_interpol=none
    cpu_type=68040
    cpu_speed=max
    cpu_compatible=false
    cpu_cycle_exact=false
    chipmem_size=4
    bogomem_size=0
    fastmem_size=0
    z3mem_size=32
    gfxcard_size=4
    chipset=aga
    immediate_blits=true
    collision_level=full
    joyport0=mouse
    joyport1=joy1
    kbd_lang=en
  • »23.06.14 - 19:29
    CountRaven
    Posts: 566 from 2007/12/10
    You can find here:
    http://www.amigaplanet.gr/forum/viewtopic.php?nomobile=1&f=7&t=15&p=55&hilit=EUae#p55
    My old config files from the e-uae setup I have been ussing back on 2008 on my Pegasos 2 system.
    Never had a problem ussing them.
    I think your system is killer and blazing fast, it would do grest on some Amiga emulation.
    Also check this link: http://www.amigaplanet.gr/forum/viewtopic.php?nomobile=1&f=7&t=932&hilit=Whdload+morphos
    [ Edited by CountRaven 23.06.2014 - 23:48 ]
  • »23.06.14 - 23:41
    Daff
    Posts: 251 from 2003/4/5
    640x512 is hires laced. SWOS native resolution is 320x200. So a 320x200 or 320x256 resolution may speed up the emulation.
    Also, used E-UAE JIT.
    http://obligement.free.fr
  • »24.06.14 - 04:45
    Tcheko
    Posts: 544 from 2003/2/25
    Change cpu_speed to 'real' (ie = cpu_speed=real). With max you'll end with 100% cpu usage whatever you do. On my powerbook 1.67Ghz, EUAE takes about 30% cpu.
  • »24.06.14 - 04:56
    Cool_amigaN
    @Daff
    Are you sure that E-UAE JIT will work with WHDLoad games?
    I am sure I 've read that there are still are severe incompatibilities with many games.
    @all
    Thanks for your suggestions. Will try them later tonight once I return home :)
  • »24.06.14 - 09:07
    analogkid
    Posts: 722 from 2004/11/3
    Are you using fullscreen? Your E-UAE display is scaled from 320x256 to 1280x1024 by E-UAE, which is very slow. Try to lower it.
  • »24.06.14 - 10:02
    Cool_amigaN
    Strang, it looks like if I use cpu_speed=real instead of max, there are is fps drop while ingame but there are two distictive pauses when euae loads: a) A blank (black) screen before Workbench 3.1 loads and b) after whdload has load the game (again a blank-black screen).. Nothing else does the trick (lowering the resolution or enabling overlay). I will test it with more games though..
  • »24.06.14 - 15:15
    Cool_amigaN
    I searched more: there seemed to exist an old version of WHDLoad SWOS 95/06 that experienced lag during gameplay (like the one I faced). What is odd, is that it gets fixed if I set the cpu speed to "real" and gets back with "max". Anyway, I will search for a newer version. Btw, the G4 speed seemed adequate to run Aladdin, so it must be ok generally speaking. On a different matter, does anyone know if there is a whdload version of SWOS with updated rosters? I did something similar myself a couple of years ago (by patching the files provided by SensibleSoccer.de) but now I am looking for a ready solution.
  • »25.06.14 - 05:55
    Posts: 1099 from 2004/9/23
    Even a slow Pegasos2 emulates most games at full speed. At least it did >10 years ago, when I played with it.
    You need a proper setup and avoid software scaling.
  • »25.06.14 - 07:17
