MorphOS Specific Popupmenu.library?
    XDelusion
    Posts: 602 from 2010/10/27
    Is there a MorphOS specific version of Popupmenu.library, or is the 68 version on Aminet (pmuser.lha) the only one?
    I ask because the MorphOS version of Dopus4 slows down my Efika when I go into the configuration menu.
  • »11.06.14 - 23:06
    Posts: 12584 from 2003/5/22
    No.
    Besides v10.8.6 on Aminet there has also been circulating a newer v10.10.1. You can get fixes for both there:
    http://www.sintonen.fi/sw/pmlib-10.8.6-fix.lha
    http://www.sintonen.fi/sw/pmlib-10.8.6-fix.readme
    http://www.sintonen.fi/sw/pmlib-10.10.1-fix.lha
    http://www.sintonen.fi/sw/pmlib-10.10.1-fix.readme
  • »11.06.14 - 23:16
    XDelusion
    Wonderful, thank you!
  • »12.06.14 - 00:03
    Posts: 1521 from 2003/2/24
    I dont think popupmenu.library has anything to do with. I ported dopus4 to MorphOS and 68k dopus works just fine so I must have done something wrong in my porting. Unfortunately I never found the problem.
  • »12.06.14 - 06:51
