Scribble Texteditor
    Jupp3
    Posts: 1193 from 2003/2/24
    polluks wrote:
    Will you include ARexx syntax highlighting next time? I'm just missing the good old highlighter API.
    Haven't checked myself, but probably it's possible to add highlight modes of your own.
  • »28.05.14 - 13:20
    Nadir
    Posts: 178 from 2003/3/17
    polluks wrote:
    Hi!
    Greetings,
    Stefan
    ARexx would need a new lexer in Scintilla and then a list of keywords. The latter is easy of course but writing a lexer depends a bit on whether there is an existing one that is similar syntax-wise. I will have a look but I can't promise anything.
    Edit: just had a quick look and there is a Rexx lexer that looks ok so I would just need to provide suitable lists of keywords. I will do that but not sure if I have the time for the next release already. I have made many changes to Scribbble lately and my focus now is to stabilize things and fix bugs.
    [ Edited by Nadir 29.05.2014 - 06:07 ]
  • »29.05.14 - 06:00
