ProStation Audio
    tolkien
    Posts: 589 from 2013/5/29
    Hello!
    Has anyone tried this beast in MorphOS recently?
    I work with audio and this prog seems very interesting years ago?
    What happened to them? mmmm Could anyone knows them?
    Could be open source?
    http://www.audiolabs.it/index.html
    Greetings.
  • »20.05.14 - 03:07
    Posts: 1403 from 2010/1/6
    Seems to do nothing after loading.......shows only GUI and hangs......
  • »20.05.14 - 05:03
    tolkien
    Thanks mate! So It's totally useless. It's a shame cos I think It was a good product.
  • »20.05.14 - 16:28
    Elric
    Posts: 52 from 2003/4/3
    Hello!
    I'm working with music (was a job, now privately, future???) and if I'm not good on ProStationAudio for now, my obective is to use it, because AudioDesk is quite good but on macos, Audacity very useful, but I want in fine a MorphOS solution.
    An idea too, stoped nowadays because of "life things", is to make working on MorphOS, the external soundcard MOTU 828 MK2... A begining of test was tried, under Yomguy's "wishdom", but betwin my $*? and His Quebec's this work is in stand-by...
    On Audilabs side, I tried to contact them for extra informations but with no reply...
    Perhaps if we contact them as a MorphOS user groupment, there will be more chances???
    For the launch hazard, I had it too, but can't yet figure out to remember what should be wrong...
    I made a try there's one year or so, and it was running... The only thing I can't figure out is the aspect of requesters, with white text and white background... I didn't arrive to tune up a PSA MUI to resolve that...
    Maybe it's time to try it again...
    Should be interesting too, to know who/how many use or want to use PSA, in order at least to try a dynamic, and at best to contact more usefully Audiolabs???
    AmiMorphOSian regards!
  • »20.05.14 - 18:03
    Posts: 613 from 2003/4/11
    I was in contact with Maurizio Ciccone, the author behind ProStation Audio back in 2003. ProStation Audio was supposed to be supplied with every sold Pegasos as a unlimited MorphOS version back then as some software addon licensed by Genesi.
    From there on, it didn't evolve much afaik. It definitely had quite some potential back in the days when MorphOS 1.4.x was still around.
  • »20.05.14 - 18:05
  • »20.05.14 - 18:15
    realstar
    Posts: 298 from 2003/2/24
    Audio Evolution 4 was looking like a nice alternative but the mixdown to disk feature doesn't seem to work for multiple tracks. It uses AHIOUT device but fails to output anything. Unfortunately the author of that software never released the source code as promised so we are left with 2 abandoned linear audio editors. I still use it for recording and saving single tracks from LPs. Prostation works too but often hangs under certain conditions.
  • »21.05.14 - 11:05
    Posts: 2224 from 2003/2/24
    Here it starts and doesn't hang, but I'm not sure if it works correctly. I don't know how to use it, but anyway finally got some audio out of it too :)
    It outputs this kind of stuff to log.. maybe something isn't drawn because of it?
    Unsupported pixfmt for mask conversion (0)
    cgx/WPAAlpha unsupported pixfmt: 0 for RECTFMT_ARGB
    Tried with ProStationAudio Titanium v5.11.
  • »21.05.14 - 12:16
    hmm - here it hangs.... think I should do it with a"vigin"-MOS-System........
  • »21.05.14 - 12:53
    Posts: 2098 from 2003/6/4
    Here it starts, but opening a file doesn't work anymore. A file requester flashes up and disappears right away then. I used it quite to some degree on my Pegasos in prae Mac mini times and IIRC it actually not only ran on 1.4.5 but also on 2.x, too.
    It's a nice and rather powerful program, albeit a few things are a bit complicated IMHO. Quite some time ago since I seriously used it though... Maybe I should dig out my Pegasos from the attic and play a bit around with that program again...
  • »21.05.14 - 18:58
    I got that at one point too, but after a restart file requesters worked again.
  • »22.05.14 - 03:16
    XzIt
    Posts: 250 from 2005/1/19
    is hd-rec still working under 3.x ?
    http://hd-rec.de/HD-Rec/index.php?site=home
    this work nicly atleast before 2.x, dont know if it wors at all anymore...
    X
  • »23.05.14 - 10:32
  • rms
    rms
    Posts: 606 from 2004/11/27
    X
    ahh, because hd rec worked under MorphOS??? For complex adio operations?
    I was never able to do anything with it...
  • »23.05.14 - 12:31
    Posts: 12589 from 2003/5/22
    > is hd-rec still working under 3.x ? http://hd-rec.de/HD-Rec/index.php?site=home
    At least starting the program, loading a bundled project and replaying it has always worked fine for me on MorphOS 1.x through 3.x. I've never tried to do more with it, though.
  • »23.05.14 - 16:42
    Yeah - works good (MOS 3.x) - I'm working with it....it's a great peece of software....
  • »23.05.14 - 17:06
