Posts: 741 from 2003/2/24
Well, the speed of MorphOS is really high.
I see no sense in using ramdisk to speed things up
But you could try
DiskImage.
I've only tested it with iso images of cd's
(really handy when searching for older versions
of command on MOS-CDs
but it should be able to handle a read/write-image which
you can copy to ramdisk on each bootup and then mount it.
Just make sure to copy it back before a reboot.
