Mailerclash: YAM vs. Simplemail
    GMKai
    Posts: 259 from 2003/4/7
    Today I decided to give Simplemail a try.
    After some tweaking around I must say it is a real great piece of software. I didn't expect anything from the test and now I am going to throw YAM away.
    Did anyone do the same?
    Why would you like to continue using YAM?
    This is really a discussion that is not possible in other software-areas as we have no choice between 2 great packages on anything else than e-mailers. I would like to see something similar about Browsers in the near future too :-)
  • »03.06.05 - 12:46
    Robin
    Posts: 741 from 2003/2/24
    I'm considering to ditch Yam,too because it's
    dev-path is no more amigalike ... but SimpleMail is too
    much graphics for me ...
    Some nights I've even considered to make my own
    client with RxMUI ;-) Lazyness is what keeps me
    tied to Yam :-D
  • »03.06.05 - 12:54
    merko
    Posts: 328 from 2003/5/19
    I did a serious test and moved all my thousands of mails to
    Simplemail. I also think Simplemail is impressive, but it was not
    ready for me when I did my test, and I don't think it is now.
    My biggest gripe was that SM insisted on colouring text in my emails
    and also when writing replies. Some of these colours could be changed,
    but some of them were not possible to change either in SM or in MUI.
    As some things were totally unreadable (something like yellow text on
    gray background or such iirc) this made SM unusable so far (even
    ignoring that I don't want emails to look like christmas trees even
    if its technically possible to read them)..
    Another problem was that it's very slow compared to YAM. When you have
    thousands of mails in each folder this makes the decision easy.
    I also like YAM better because I can have a textured background when
    writing mails. I've gotten used to having a slightly textured "paper"
    pattern and plain-coloured makes me feel uncomfortable now. ;-)
    Anyway, YAM also has its flaws, most important for me is the way it
    just hangs for a while when it doesn't manage to connect, and
    meanwhileit will also not redraw its window due to lazy programming. I
    guess that sooner or later SM will be the better program, but for now
    I'm staying with YAM.
  • »03.06.05 - 13:17
    DJBase
    Posts: 745 from 2003/4/6
    I switched from YAM to SimpleMail last year and I am happy with it. No crashes, works how it should.
  • »03.06.05 - 13:30
    SoundSquare
    Posts: 1214 from 2004/12/1
    SimpleMail needs improvements but we had several updates already not so long ago so it should become better and better. Best email client for me on amiga/pegasos, i never really liked Yam. I do agree with the colours in emails issue, we should be able to disable it completely.
    sweet piece of software.
  • »03.06.05 - 15:44
    weiseb
    Posts: 214 from 2003/3/29
    I prefer Yam because of the more advanced filter and search functionality.
    But maybe I missed something in Simplemail
  • »03.06.05 - 16:10
    Kaczus
    Posts: 199 from 2003/9/6
    I must add, simplemail is unusable for me, because there is no
    multiuser support in simplemail :(
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »03.06.05 - 17:41
    Toto
    Posts: 268 from 2003/4/20
    I think both programms are very good, and both run very well on my Amiga's and Pegasos. Until half a year ago I used Yam but nowaday's I prefer Simplemail because imho it's a tiny bit better.
  • »03.06.05 - 19:32
    Brumiga
    Posts: 274 from 2004/4/3
    Hello,
    There is also the problem of the attachment files in mails. When one has downloaded the attachment files one want to remove them from the mail. In Yam one can easily remove them if he considers that it is not necessary to conserve them. But in SimpleMail i did not find how to perform the same manipulation. I asked the question on amigaimpact irc channel and the answer was that it is not possible to perform this manipulation.
    Brumiga
  • »05.06.05 - 13:33
    matt3
    Posts: 782 from 2004/2/10
    Recently switched to YAM after using Simplemail for many years.
    YAM is a real nice client, seems faster.
    Will report in after I get some more time with it...
    Matt
    Brumiga wrote:
    Hello,
    Brumiga
  • »30.12.13 - 01:04
    realstar
    Posts: 298 from 2003/2/24
    I have tried Simple Mail a few times but always seem to switch back to Yam eventually. I like the feel and configuration of Yam more. Also I didn't see a way to disable the integrated read pane on the main interface of SimpleMail. I prefer to open a seperate window to read mails. Yam has an option under:
    'Configuration->Look&Feel->Main Window->Show Embedded Read Pane in main window'
    that can be turned off.
    [ Edited by realstar 30.12.2013 - 11:03 ]
  • »30.12.13 - 17:02
    Henes
    Posts: 507 from 2003/6/14
    Try to untick this entry:
    menu Preferences -> [x] Show Selected Message?
  • »30.12.13 - 17:17
    realstar
    Henes,
    Ahhh. Nice feature. Guess I missed it last time.
    [ Edited by realstar 30.12.2013 - 13:09 ]
  • »30.12.13 - 19:09
    DanicaTalos
    Posts: 457 from 2010/10/15
    SimpleMail = IMAP-Support
    YAM = Only POP3-Support
    I need IMAP and SimpleMail 0.40 for 68k works amazing on my Mac Mini with MorphOS 3.4.
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.20
  • »31.12.13 - 08:13
    Jambalah
    Posts: 820 from 2008/3/30
    @DanicaTalos & all:
    SimpleMail v 0.40 for MorphOS is out:
    http://www.meta-morphos.org/article.php?sid=1677
    Thanks Henes for this upgrade!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »31.12.13 - 09:26
    VooDoo
    Posts: 189 from 2005/8/24
    My choice is YAm using it from 1997 and defintly the best mail clinet for me ! 3-4 times try Simple Mail but is not for me, YAm is faster , get multiuser support and that is ALL!
    Long live YAm :)
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »31.12.13 - 12:35
    Posts: 647 from 2004/4/15
    I really like SimpleMail, because it supports IMAP and looks more modern.
    THX for new MorphOS version which is much faster than the 68k one.
  • »31.12.13 - 13:39
    DanicaTalos
    68k Version is very fast. The MOS Version doesnt work (GMail IMAP).
    [ Editiert durch DanicaTalos 01.01.2014 - 17:28 ]
  • »01.01.14 - 09:35
    analogkid
    Posts: 715 from 2004/11/3
    Long live YAm :)
    It's the same for me. I'm using YAM since 1999 or so, first on Amiga and since 2003 on MorphOS, and it's still my very favourite. Surely it lacks some standards like IMAP support or HTML rendering, and it's still using the ev1l NList classes. But IMHO it's still better than SimpleMail.
  • »01.01.14 - 12:03
    matt3
    I'm going to go back to Simplemail. YAM has a few bugs I uncovered:
    1. The mail list doesn't work properly (it goes away as I type the email, weird.
    2. When new mail arrives I can't get it to go the first unread message...
    So, are there any images availabe for Simplemail? One nice thing with YAM is the themes that are built in. Anyone build a new button set for Simplemail and have any recommendations on making the GUI look better?
  • »03.01.14 - 03:35
    Jambalah
    SimpleMail 4.0 MorphOS version has a bug: when I use the horizontal moving slider of the mail list window everything inside disappears. Moving the vertical one or selecting a mail will make everything come back to normal state.
    I tried SimpleMail 4.0 68k and this strange behaviour doesn't occour.
    Pegasos II 1 ghz
  • »03.01.14 - 16:12
    matt3
    A follow up review:
    Simplemail is a better email client in the follow respects:
    1. The addressbook is more capable in SM, including handling multiple email addresses.
    2. Emailing a group works well in SM, in YAM there is a bug with it.
    3. Simplemail seems overall less buggy than YAM. I used both side by side for a few weeks and that is my observation.
    I will say that SM is slow to load with a huge amount of email, YAM does not seem to have such an issue with it. with 7000 emails it take about 10 seconds to load on my PB 64 1.67 and an SSD.
    I did download Simplemail for AROS and copied the images to give SM a fresh look (exactly like YAM:))...
    A big thank you to Henes for porting it!
    [ Edited by matt3 06.01.2014 - 07:15 ]
  • »06.01.14 - 11:13
    matt3
    Switched back to YAM for MOS for the following reasons:
    1. Simplemail gave an xml error on boot up and I'm to lazy to fix it.
    2. YAM just had a recent update and seems to be more actively developed.
    3. Like the notifications in YAM concerning updates.
    The only issues I have found with YAM:
    1. Sort of email and starting with new email seems to now work consistantly.
    2. YAM's email handling for groups isn't as nice and feature rich as Simplemail.
  • »25.04.14 - 09:11
