Grease Monkey Set Up:
    In_Correct
    Posts: 245 from 2012/10/14
    How do I install this script?
    http://userscripts.org/scripts/show/103507
  • »24.04.14 - 17:31
    Posts: 1090 from 2004/9/23
    Just download the script (Sourcecode) (or cut and paste into an editor), save to scripts drawer and add it using the window/scripts settings window.
    Afterwards it should work unless it is using system specific code not compatible with MorphOS.
    Geit
    PS. Nice one. This was really annoying. :)
    [ Edited by geit 25.04.2014 - 02:46 ]
  • »24.04.14 - 22:45
