Latest AHI drivers supporting SBLive?
    Leon
    Posts: 93 from 2003/11/28
    As you know (or maybe not), the latest AHI archive for MOS includes AUDIGY drivers. I wonder if these drivers work with SB Live soundcards?
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »30.01.04 - 16:51
    Miky060
    Posts: 694 from 2003/2/24
    The SB Live card was the first one to be supported by these drivers. I have one running. I don't know nobody, instead, useing a Audigy. Someone here?
  • »31.01.04 - 00:05
    poundsmack
    Posts: 1346 from 2003/6/8
    i will once i have mine
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »31.01.04 - 00:32
    Leon
    I myself have plugged a Creative SB Live into a free PCI slot of my Peg2 and without any problems it produces clear output. It has much much better and higher output than the onboard AC97 chip of the Peg, there was no problem with the AHI. AHI recognized the EMU chip and I selected 16-bit Hi-Fi Stereo++. I would like to thank to Martin Blom for this, as Creative cards are very important for the consumer industry and one of the very first questions of a potential Pegasos owner is 'Is there support for latest sound cards like Audigy or Live?'. Now I can answer proudly: "YES!"
    Proud owner of:
    Efika
  • »02.02.04 - 03:04
    Posts: 12 from 2003/8/7
    Hello,
    i've installed my SB-Live in my Peg properly,
    now i will change the input-levels!
    Which mixer-tools can i use?
    Can i use ac97mixer, and where can i download this?
    Ciao Mario
  • »14.02.04 - 12:27
    Leon
    Can't you use Pegasos Mixer that comes with MorphOS?
    Proud owner of:
    Efika
  • »14.02.04 - 18:47
    Hello Leon,
    no, the mixer that comes with MOS-1.4 or older is
    for "onboard-soundchip" only!
    I hope, the AC97mixer will control the SBlive,
    but the download-link is dead!
    Ciao
  • »14.02.04 - 23:19
    Leon
    Try this (It is the 1.9 version of AmiMixer for Amithlon, 26,956 bytes):
    http://www.pegasos-tr.com/bin/ac97mixer1.9_amithlon.lha
    Tell me if it works :)
    Proud owner of:
    Efika
  • »15.02.04 - 15:38
    Leon
    Uh, just found out that SBlive support comes with v2.0. So 1.9 will probably not work. And the actual version seems to be 2.1. And yes, there is only one download pointing to Frank Fenn's website and it is dead. :(
    Proud owner of:
    Efika
  • »15.02.04 - 15:45
    Leon
    There it is, searched my HDD little bit and found the 2.1 version of AC97Mixer:
    http://www.pegasos-tr.com/bin/ac97mixer2.1.lha
    Proud owner of:
    Efika
  • »18.02.04 - 16:41
  • »18.02.04 - 19:41
