Amiga Lightwave in Morphos
    Doraemon
    Posts: 137 from 2003/7/1
    Hello, I have installed the LW 5.2 from amiga in morphos and it runs fine but only the layout.
    If I go to the modeler I get a message: "Can't enter modeler: Error 408"
    The same Lw runs perfect in a my friend's peggy.
    I think that may be something bad in my morphos... a missed screennmode or something.
    Any idea???
    I wav investigating with snoopdos without good luck.
    (I had it running a few months ago, but now it don't run)
  • »15.02.04 - 22:17
    realstar
    Posts: 298 from 2003/2/24
    You could try adding a screenmode ID into
    Modeler's config file to run it stand-alone
    from Layout. (LightWave_Support/MOD-config)
    Add a line similar to this in the config file:
    ScreenModeID 40920002
    You can use a utility from aminet called
    "GetHexModeID.lha" to find an appropriate
    setting and make sure you specify an 8bit
    screenmode. Then start Modeler executable
    stand-alone and see what happens. Also
    make sure "arexxport.library" is in your
    libs drawer.
  • »16.02.04 - 06:32
    poundsmack
    Posts: 1346 from 2003/6/8
    where can i get the last release of lightwave for the amiga?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »16.02.04 - 08:27
    Posts: 125 from 2003/9/8
    Is Amiga Lightwave 5.2 (5.1) free or still comercial version?
    On their web isnt any mention about Amiga version, its price and purchase.
    JACK - 3D gfx artist
    Config: Pegasos 2 G3/600 MHz, 256 MB SDRAM (Kingmax), ATI Radeon 9200 Pro 128MB, 120 GB HDD
    My new web: http://jack-3d.wz.cz
  • »16.02.04 - 12:32
    Doraemon
    I tryed with 800x600 640x480 and 640x512 screenmodes in 8 bit without good luck. :(
    Any idea?
    What screenmode are you using in Ambient? And in modeler?
    Thx4all and sorry for my bad english
  • »16.02.04 - 15:02
    Estrayk
    Posts: 142 from 2003/12/30
    NewTek stopped Amiga version years ago, but still can be find for a purchase:
    http://www.amigis.nl/lightwave.html
    so, ISNT an Abandonware product yet! get a copy its illegal action.
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »16.02.04 - 15:02
    I have Ambient 1024x768x16 and Modeler 1024x768x8. Modeler resolution depends on that utility.
    And does your Layout run?
  • »18.02.04 - 17:52
