Torrent clients too out of date?
    Madgun68
    Posts: 60 from 2003/4/16
    I recently decided to catch up on one of the television shows I used to watch, and have been downloading episodes via torrents.
    With clients that I have tried, I'm lucky if it reaches 8kB/s. Utorrent is currently seeing 100+ under XP.
    So far I have tried BeeHive, ctorrent, bittorrent and mldonkey. Mldonkey wouldn't start transferring anything while the others averaged less than what I showed above.
    Anyone had decent luck with these recently?
  • »06.03.09 - 05:18
    Posts: 12552 from 2003/5/22
    Tried this?
  • »06.03.09 - 05:26
    CISC
    Posts: 619 from 2005/8/27
    Make sure you forward the appropriate ports (6887-9 by default) in your router/firewall, otherwise you will indeed be lucky to reach 8kB/s...
    Personally I have best results with the latest BitTorrent client on MorphOS (usually because it supports DHT), though it's worth noting that file-access always was sub-optimal (but that shouldn't hinder a decent download speed) with the ixemul version on MorphOS 1.4.x
    - CISC
  • »06.03.09 - 05:55
    Madgun68
    Tried this?
    I did try it.. A little better results. It eventually quit responding at 10%. I restarted the program and it stopped again at 13%. I gave up. (Didn't freeze the machine. I could still break the program but it wasn't responding to the network anymore.)
    I also did a bit of searching looking for cli options and ran across this.
  • »07.03.09 - 13:57
    Madgun68
    - CISC
    Are you referring to version 4.3.6? That's the most recent one I can find. It does indeed work better than the others. (All of them appear to be a little aged. I haven't ran across anything ported after 2006.)
    As far as ports go.. I just set up the machine with a static IP and configured the router so it is in it's "DMZ." Easier than having to modify the forwarding rules when the IP changes.
  • »07.03.09 - 14:09
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @Madgun68
    yes, transmission 0.6.1 wasn't very compliant to the protocol. Besides, it has like you noticed a stall issue (restarting it is enough, but it's not a solution).
    Maybe a more recent version would fix this. Assuming it follows the protocol correctly now, it would deserve an integrated gui anyway. :)
  • »07.03.09 - 14:48
    Madgun68
    @Fab
    The wiki says versions after 0.70 corrected the compliance issues. (And that was in 2007 so one would expect newer versions to behave better.)
    A gui? That would rock!
  • »07.03.09 - 16:28
  • tom
    tom
    Posts: 149 from 2003/7/22
    MLDonkey works fine for me. Not really fast, but quite stable.
    800MB (if new) takes one day downloading (sometimes donkeyfiles are as fast)
    MLDonkey is downloading 24 hours a day without problems.....
    regards, Tom
  • »07.03.09 - 18:58
    dake
    Posts: 204 from 2007/9/14
    I am also using MLDonkey.
    Tried alot of different torrent programs and this is really good i have used it for years.
    Read the manual and try this wonderful thing.
    There is a new port of MLDonkey 3.0 at http://natmeg.stamey.at/ports/
  • »08.03.09 - 07:50
    CISC
    Hmmm, right, I suppose I never bothered making a frozen binary of 4.4.0 (which I am running here as an "uncompiled" python script), though I don't think there were many important changes between those versions...
    If yomgui's python port has the right components built in this version should run fine for everyone else too, later versions might work as well, but I doubt it as they switched to Twisted, which had several issues on MorphOS IIRC.
    - CISC
  • »08.03.09 - 08:39
    SoundSquare
    Posts: 1214 from 2004/12/1
    BeeHive is kinda efficient here, i get around 50Kb/s on most torrents, and this is almost the maximum rate my poor DSL line allows.
    Setting up your router is very important, don't override this part.
  • »09.03.09 - 19:50
    magnetic
    Posts: 2129 from 2003/3/1
    Hi Soundsquare
    Beehive has a gui right? Does it work OOTB?
    Has ML Donkey grew any in regards to a GUI or still using a webrowser or whatever it is..
  • »10.03.09 - 05:48
    Posts: 423 from 2005/4/9
    beehive has a gui. its simple but usable. if you wanna leech more than one torrent you have to run more beehives, fe. unfortunately, some torrents can kill beehive by loading them (and it kills the whole system). but when it works the torrents downloading with my max bandwidth.
    mldonkey (3) still doesnt has a gui afaik, but the html interface not that bad.
    we can use torrets and some p2p in these ways but a better client would be very welcomed (and a dc++ client also:).
    zx.spectrum@3.5
  • »10.03.09 - 09:20
    SoundSquare
    Hi Soundsquare Beehive has a gui right? Does it work OOTB?
    hi Magnetic,
    yes it does, and as sadddam said it works nicely as long as you set up the right ports. It's as easy as launching it, selecting your torrent file and destination folder.
    I only had some problem when trying to open a second behive for another torrent at the same time, the second torrent would never start. I didn't try to find a way to get around it though.
    [ Edited by SoundSquare on 2009/3/10 14:11 ]
  • »10.03.09 - 11:10
    hm, i could use 2-3 beehive at the same time (never tried more). something wrong with your setup i guess.
    i've also configured ambient to open beehive at doubleclick on a torrent file.
    sadly the same does not work for ibrowse, it wants to start beehive in cli mode (ctorrent)...
    zx.spectrum@3.5
  • »10.03.09 - 11:43
    Drako^lM
    Posts: 144 from 2005/8/10
    We need on MorphOS a good torrent . New transsmision with GUI hmmmm :)
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »14.03.09 - 20:45
    hooligan
    Posts: 1948 from 2003/2/23
    I spoke to Shape and apparently there is a new version of Enhanced CTorrent, so there might be an update to Beehive soon. Fingers crossed.
  • »14.03.09 - 21:12
    catohagen
    Posts: 297 from 2003/5/20
    Whats wrong with ?Torrent ? :)
  • »15.03.09 - 16:51
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Why so low transfer rate?. Shouldn't it go as fast as your connection allows?.
  • »26.06.12 - 11:42
    This may help:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=7618
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=8111&start=35
  • »26.06.12 - 13:29
    xyphoid
    Posts: 870 from 2008/7/11
    I would research these threads on using mldonkey. I use it exclusively now and it is fast enough. It works with only a few hic cups, mainly due to the torrent file, but it has a webinterphase which works on owb (http://localhost:4080/) once mldonkey is started.
  • »26.06.12 - 13:55
    boot_wb
    Posts: 874 from 2007/4/9
    @Xyphoid
    Same here. Enqueuetorrent & P2PGuardian are also nice additions. :-)
    The web inerface may be plain-looking (compared to fe. uTorrent's funky graphs) but it is surprisingly good once you get used to it.
    I do find that the web interface freezes intermittently though (possibly the core too, can't remember tbh), but it's easy enough to ctrl+c the relevent console and restart it as a workaround.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »26.06.12 - 15:04
    dake
    If you encounter that MLDonkey don't respond at all, you must increase the loop_delay variable in downloads.ini
    MLDonkey also stops to respond until a file allocation is done and this can take a while depending on harddrive and file size, in this case the loop_delay variable has no effect.
  • »26.06.12 - 16:35
    xyphoid
    Lately, (actuallly months now, but I've reached my patience level) MLDonley isn't getting my entire torrents, and it just idles at a low d/l% and of course after 12hrs or so the nework issues kick in and there is no more d/l. Restarting does the same. Anyone else using MLD with these issues? Any solutions, or torrent options? CTorrent doesn't bring in my files.
    Be nice if we got transmission ver like Pc/ubuntu/mac or perhaps web interface
    http://www.transmissionbt.com/images/screenshots/Clutch-Large.jpg
    [ Edited by xyphoid 29.03.2014 - 09:47 ]
  • »29.03.14 - 13:34
    Cego
    Posts: 738 from 2006/5/27
    yeah i have the same problem with mldonkey. no download at all. any update on this?
  • »02.04.14 - 20:30
