RemoteShell with key file?
    ciVic
    Posts: 45 from 2013/6/2
    Hi all,
    Is it possible to use a keyfile within RemoteShell? I can run "ssh -i path/to/keyfile server" and it works but the RemoteShell with its sshcon would be better. Thx!
  • »06.03.14 - 12:34
    Posts: 3327 from 2003/3/5
    ciVic wrote:
    Hi all,
    There are two ways to do this, actually. First is to move your key into SYS:Applications/RemoteShell/Files/Conf. The other is to install the SDK, setup your HOME: dir and put these files into HOME:.ssh like you would do on linux and uncheck the "Use builtin OpenSSH" box in RS.
    You can also just add the -i param into the Login field in the SSHCON gui - since that's added to the ssh launch command line, it'll work just fine.
  • »06.03.14 - 14:27
    ciVic
    I tried the first option but what should be the filename for the conf dir?
  • »06.03.14 - 16:45
    That'd be like regular .ssh dir contents, so id_rsa & id_rsa.pub
  • »06.03.14 - 17:12
    Jupp3
    Posts: 1193 from 2003/2/24
    See this thread.
  • »21.03.14 - 07:51
    ciVic
    Thx all, the id_rsa file works!
  • »21.03.14 - 19:17
