Youtube acting up yet again...
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @boot_wb
    This youtube_centre script is quite impressive. Though one might be confused with all its options. But it's great to have this, considering the mess youtube constantly creates.
    That said, youtube.js is lighter and should work for all videos as well, now. :)
  • »26.02.14 - 07:02
  • vox
    vox
    Posts: 616 from 2003/11/24
    Fab wrote:
    redrumloa wrote:
    Fab, you tired of hearing from me? :-/
    It works fine here, both in HTML5 mode and in Flash replacement mode.
    Do you have a link that doesn't work?
    When will their HTML5 no-need-for-Flash support be final?
    Google behaving like Steven.
  • »26.02.14 - 08:10
    Yasu
    Posts: 1724 from 2012/3/22
    It seems that YT is acting up once again. I can't play any movies anymore. When I click links, all I get is a big black box. If I reload, I can at least download the movie. But with or without HTML5-player, nothing plays in YT.
    My MorphOS blog
  • »28.02.14 - 09:52
    Posts: 12572 from 2003/5/22
    Try spoofing as recent Firefox in Youtube's HTML5 mode (i.e. without using youtube.js). This works here. Read there for a more extensive explanation by Fab from 3 weeks ago:
    http://www.amigans.net/modules/xforum/viewtopic.php?post_id=87113#forumpost87113
  • »28.02.14 - 11:18
    Yasu
    @Andreas_Wolf
    I will try that.
    Curse you Youtube! :-x
    My MorphOS blog
  • »28.02.14 - 11:49
  • Fab
    Fab
    @Yasu
    And just install latest available scripts at http://fabportnawak.free.fr/owb/scripts/ (youtube.js and youtube_fullscreen_fix.js). Or use Grunch to update them.
    In latest youtube.js, I added support for the new youtube links that have an encrypted signature (more and more widely used), so they should hopefully all play (until youtube breaks it again).
    You can also have a look at this youtube_centre userscript BootWb mentioned, it works nicely (but you'll have to configure it to use HTML5 and so on).
  • »28.02.14 - 11:54
    Yasu
    @Fab
    That was the first thing I did. Which is why I mentioned that it broke again here.
    My MorphOS blog
  • »28.02.14 - 13:01
  • Fab
    Fab
    Yasu wrote:
    @Fab
    Well, any link that wouldn't work?
    Anything i tried worked here, 15 minutes ago.
  • »28.02.14 - 13:55
    Yasu
    @Fab
    Really? Weird. Nothing worked when I tried. Have you HTML5 video switched on or off?
    My MorphOS blog
  • »28.02.14 - 14:12
    amiga-dave
    Posts: 8 from 2014/3/8
    I am new to MorphOS and loving it so far on Mac Mini 1.5 Ghz 512mb ram, i too cannot get youtube vids to work, i have these in my scripts folde: Facebook HTML 5 Converter, Youtube HTML 5 converter, Youtube Full screen Fix and Youtube - EZ Download, all latest from Fab's website, i can download the videos with EZ Download and that is all.
    I would really like to get this working before buying the full version.
  • »09.03.14 - 23:21
    Posts: 1362 from 2004/2/8
    So you have these scripts, but are they enabled (menu: Windows/Scripts)?
  • »10.03.14 - 04:57
    Posts: 2220 from 2003/2/24
    Have you also updated the OWB itself? OWB on MorphOS ISO is a bit old already too. http://fabportnawak.free.fr/owb/
    And all those scripts are enabled from Scripts window, not just copied there?
  • »10.03.14 - 05:05
    Yasu
    I can't get Youtube to work either, unless I spoof as Internet Explorer 10 with HTML5-video on. And yes, I got the latest of everything.
    This is new behaviour for me since YT used to work without spoofing and HMTL5-video. But since YT are jerks, I'm satisfied with this solution for now.
    So my advice for newbies is, get Grunch and use it to update everything and try spoofing as another browser and switch HTML5-player on and off until you get it to work.
    My MorphOS blog
  • »10.03.14 - 09:40
    Posts: 7 from 2014/2/23
    yes they are enabled and i too can only get youtube to work spoofing IE 10
    I am loving MorphOS so much but this is dissapointing
    [ Edited by sliceoflife 11.03.2014 - 00:00 ]
  • »10.03.14 - 22:58
    Yasu
    @sliceoflife
    That is avtually Youtubes fault and not Morphos. Blame them :-)
    My MorphOS blog
  • »11.03.14 - 12:43
    Posts: 1390 from 2010/1/6
    It seems that YT changes something again. Since today here (Austria) we have the same problem, but it can be played it with getvideo and Mplayer or by clicking to "18" in the line below the video (view as HTML5). May take some time till this line appears..........
    [ Editiert durch Amigaharry2 11.03.2014 - 19:22 ]
  • »11.03.14 - 17:19
  • Fab
    Fab
    As said above, be sure to have OWB 1,23 and latest scripts at http://fabportnawak.free.fr/owb/scripts/ (youtube.js and youtube_fullscreen_fix.js, only those two are really needed for youtube). And as said above, be sure to ADD/ENABLE them in scripts manager window.
    I just tested a few seconds ago, and all the videos i stumbled on worked, either in normal HTML5 mode, or in Flash-replacement mode.
    And finally, as said above again, it's not morphos or the browser's fault if Youtube can sometimes break. They only have a very small fraction of their videos available as HTML5 mode, and for the rest you need hacks to replace Flash, which can obviously break each time they change something in their page.
  • »11.03.14 - 18:16
    I have not come across a video that doesn't work here (that's without using youtube.js) in a long time. Do you have an example URL?
  • »11.03.14 - 20:29
    @Fab: I've installed latest scripts and they are activated. But there seems to be a problem at YT only yesterday (11.3.2012) - videos where showed, but cannot be played. Today it's well running again. Maybe thats different in other countries.....
  • »12.03.14 - 05:05
