MUIBase 3 and pdf export
    r-tea
    Posts: 317 from 2005/3/27
    Does anyone have an experience with MUIBase Query editor and exporting its results to PDF file?
    Recently I've created a database with several attributes, which are represented in Query editor by columns.
    By clicking RMB on the top bar of columns, a pop-up menu appears in which one can deactivate (exclude) some of columns.
    But after I exclude one of them (it disappears in Query editor) and then export the query result to an PDF, that column still exists there in PDF.
    Am I right it should affects on PDF output or not?
  • »02.02.14 - 12:27
  • MH2
    MH2
    Posts: 7 from 2014/2/13
    Have you try too mail on the MUIBase Yahoo email-list?
    I have one big datbase, that have relation , buttons, and i can even start an mp3 fil whit an button.
    If i want to make an pdf file a do this steps.
    1. Go too the Queries editor
    2. Type (in my case) SELECT File From Encode, If I type SELECT * From Encode, the rsult will be all data i have.
    3.Press the RUN button to get the list of only files data
    4. Press the PDF button, and type where the pdf file should be saved ( in my case Ram Disk:).
    5. Then I can open the PDF file in the Ram Disk:
  • »13.02.14 - 14:37
  • rms
    rms
    Posts: 606 from 2004/11/27
    For now MUIbase does not check the status of fields abd that's why it does not hide them when exporting to pdf.
    But this can/will be changed for one of the next new releases of MUIbase (as per Steffen Gutmann).
    From my point of view, in fact this is quite a handy feature ;-)
    Regards
    Christoph
  • »17.02.14 - 12:15
