MEGA Cloud Storage
    Intuition
    Posts: 1116 from 2013/5/24
    Has anyone managed to get http://mega.co.nz to work with Odyssey?
    I know the majority of the site is written in client-side Javascript so will be executed by an interpreter as there is no JIT compiler for PPC WebKit as far as I am aware, but hte thing just won't load for me.
    I've left it for over an hour on my Powerbook and it just sits on the cloud/cogs loading page with a progress bar but nothing happens after that,
    The CPU usage goes up to 99.6 for about 5 minutes and then drops back down to normal levels and the progress bar looks about 90% loaded.
  • »27.07.13 - 19:30
    Posts: 12572 from 2003/5/22
    > Has anyone managed to get http://mega.co.nz to work with Odyssey? [...] hte thing
    > just won't load for me. I've left it for over an hour on my Powerbook and it just sits
    Works here on Mac mini with OWB 1.20. The progress bar loads to 100% and then the actual site appears.
  • »27.07.13 - 20:30
    Piru
    Posts: 624 from 2003/2/24
    If it works, expect it to be slow. The site does AES-128 cryptography in javascript: https://eu.static.mega.co.nz/crypto_31.js
    It certainly would benefit from js JIT, but there is nothing preventing from working without.
    That being said, mega often has trouble loading for me. It fails often with Firefox for example, while working ok with Chrome.
  • »27.07.13 - 21:34
    boot_wb
    Posts: 874 from 2007/4/9
    As an alternative, has anyone looked at the possibility of a Storage Made Easy client / desktop tools?
    They seem to want to support everything, filesystem seems to be through fuse, and the developer page provides some API information for building compatible tools.
    It's beyond me to discern whether it's feasible, but as it provides a portal for most/all cloud services, it looks pretty desirable.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »10.02.14 - 21:19
