Hi everyone. I've just found a bug in the latest UAE-build. (not the JIT one)
If I enable uae_rcli in the startup-sequence my keyboard isn't recognizing any keystrokes. If uae_rcli is disabled everthing is right and it's possible to quit UAE by pressing CTRL+ALT+Q.
I'm Using Morphos 3.4 on an Ibook G4 14" with 1.42 Ghz. No Commodities running.
Ok I've tested your solution but this doesn"t solve the problem. UAE get's realy slow and the sound starts stuttering. Running the WHD-Load Games right out of UAE work's like charm. Maybe it's a iBook only problem. I just transfered my UAE-Files right from my dead Powermac where everything runed very well. Ok a little bit slower.
