Poseidon USB bug
    Minuous
    Posts: 166 from 2010/2/12
    Does anyone know who is currently maintaining the Poseidon USB stack? I have a bug report I want to submit: I have worked with the maintainer of the MOS lowlevel.library and we have determined that there is a bug in Poseidon's patching of the SetJoyPortAttrs() command which can cause the system to hang.
    [ Edited by Minuous 26.01.2014 - 13:47 ]
  • »26.01.14 - 02:46
    Posts: 1521 from 2003/2/24
    You can report it via bug report form in About MorphOS dialog.
  • »26.01.14 - 05:45
    Minuous
    The MorphOS computer isn't connected to the Internet, so I will have to copy it over to this machine and email it manually. I can't see an email address, I would assume support@morphos.de but it specifically says not to send bug reports there...?!
  • »26.01.14 - 18:29
    Posts: 611 from 2003/4/11
    Use contact(at)morphos-team.net if the related MorphOS machine is not connected to the internet. The MorphOS bug report form is still the recommended way to send bug reports, though.
  • »26.01.14 - 21:19
    Minuous
    OK, done...
  • »28.01.14 - 15:49
    Piru
    Posts: 624 from 2003/2/24
    Minuous wrote:
    OK, done...
    I've sent you a clarifying question via email, did you get it?
    PS. Please check your spam folder, it seems Google has decided to consider all Hetzner servers as source of spam. Sigh :-(
    [ Edited by Piru 30.01.2014 - 15:16 ]
  • »30.01.14 - 05:37
    Minuous
    Sorry for not checking this thread...I have now replied to your email.
  • »03.02.14 - 21:20
