Last mui class and wookiechat
    VooDoo
    Posts: 189 from 2005/8/24
    After installing last version MUI class get problem whit Wookiechat , cant start it!
    Get error ilegal instuction , and after replacing nlistview.mcc class to older version Wookie is running again!
    Anyone have the same problem? Thanx
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »25.12.13 - 15:27
    Posts: 655 from 2004/4/15
    Same problem here!
  • »25.12.13 - 17:02
    Posts: 2581 from 2003/2/24
    NList.mcc and related classes have long been known to be buginfested crapware, thats why there are some older and still somewhat working versions included in the MorphOS-iso.
  • »26.12.13 - 06:22
    Posts: 12572 from 2003/5/22
    I don't think this is true. Where exactly are they supposed to be hidden in your opinion?
  • »26.12.13 - 18:34
    VooDoo
    but when using older Yam (2.9) is not working! On oS4 have the same mui class version and no problem..Wookiechat is running just fine..
    A1200 sandwich
  • »26.12.13 - 18:37
    I switched back to 0.116 release of NList classes, which are working with WookieChat.
    I do not use YAM at all, because SimpleMail IMHO much better.
  • »27.12.13 - 10:25
    Piru
    Posts: 624 from 2003/2/24
    NList classes are notoriously buggy. They're so buggy and beyond repair that we decided to get rid of the NList class usage in MorphOS components/applications, wherever possible (IIRC that happened several MorphOS releases ago).
    This incident (and several earlier similar incidents) back up that decision.
    Unfortunately some 3rd party applications still use them, however, and thus situations like this can arise.
    Unfortunately there is very little we can do here, other than to point you to direction of the NList class developers. It's their mess, and they should fix it.
    [ Edited by Piru 28.12.2013 - 01:11 ]
  • »27.12.13 - 13:11
    VooDoo
    Piru do you have maybe contact mail for NList class developers? I can get find it in archiv.Thanx
    A1200 sandwich
  • »29.12.13 - 11:14
    danwood
    Posts: 95 from 2009/10/5
    Ah this is why my Wookiechat has stopped working. Where can i get the older version of nlist.mcc?
    EDIT: Never mind, nlistview 19.91 seems to sort it.
    [ Edited by danwood 08.01.2014 - 00:29 ]
  • »07.01.14 - 23:23
    VooDoo
    New MUI class version is on Aminet!!! Now Wookiechat again working under MOS!
    A1200 sandwich
  • »27.01.14 - 18:16
