Posts: 1597 from 2012/11/9
Fab wrote:
You might want to type "setenv save OWB_POLLTIME 1" in a shell, and restart OWB. It may (or may not) be faster for you.
At least, with this value, i once tested OWB at 10MB/s over my LAN.
It would be good to have ALL the extraneous SETENV commands - that are additional to the MOS update/system releases, put somewhere so we can all add them into our systems rather than stumble across them here and there, like I have done now.
Maybe they could be put in the MOS library, with an explanation to say what they do and for which application/program they affect. I'm sure there are many of these, and similar, commands that I don't know about, and as a result of which I am sure my system is not as streamlined/efficient as it could be.
I stumbled across the MacMini Dual-Boot option by using SETENV to make MorphOS be the first OS to boot on such a system.
Simple when you know, but very frustrating until you find an explanation of how to achieve what you want to do when you have no idea how to accomplish it yourself.
Just a thought, nothing more.
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
